alias_marks Posted September 28, 2006 Share Posted September 28, 2006 Hey guys, hope all is well. Check out these corners and tell me what you think. I can't seem to shake this corner gradient that tends to be occuring on all my lofted objects. I've tried to convert to poly's, subdivide among other modifications to the geometry with no luck. The all have UVW maps too. I know the corners should be sharper just by looking at the corners below them (which are extruded lines). Why are they fading to black? It even has the opposite problem on the opposing corners where it becomes way to bright. I'm using mental ray, Final Gather with no GI. For this render I've just used the default Standard Material. Thanks for any insight. Have a good one! Michael Link to comment Share on other sites More sharing options...
STRAT Posted September 28, 2006 Share Posted September 28, 2006 check your smoothing groups Link to comment Share on other sites More sharing options...
alias_marks Posted September 28, 2006 Author Share Posted September 28, 2006 Excellent Advice Strat! Thanks. For anyone else out there with the same problem, make sure when your doing a loft, uncheck "smooth length" and "smooth width" under "surface Parameters" if your trying to get sharp edges. Thanks again, I'd been stuck on that one for a couple days. Michael Link to comment Share on other sites More sharing options...
Andrew Roane Posted October 3, 2006 Share Posted October 3, 2006 Thanks, I posted the same problem a few weeks ago, and I never resolved the issue completely Link to comment Share on other sites More sharing options...
