ZFact Posted September 28, 2006 Share Posted September 28, 2006 Hi; I want to twist a high rise building... very simple model of 1 polygon for wall and 1 polygon for glass... why does the glass twist differently to the walls? Link to comment Share on other sites More sharing options...
AJLynn Posted September 28, 2006 Share Posted September 28, 2006 Post a C4D file so we can see exactly what's going on. Link to comment Share on other sites More sharing options...
ZFact Posted September 28, 2006 Author Share Posted September 28, 2006 Post a C4D file so we can see exactly what's going on. model attached Link to comment Share on other sites More sharing options...
AJLynn Posted September 28, 2006 Share Posted September 28, 2006 It has to do with the mesh density - on your glass box, there are no intermediate points between the top and bottom, and it needs the higher level of detail to deform the mesh. The conrete part has a high level of detail, so it works. I tried it with the glass part replaced with a cube, size 49*300*24, coordinates 0,150,0, with segments increased to 10,30,10, and it worked fine. I had the same problem last year when I was IK-skeleton-rigging the Boston waterfront so it could walk around. (Animation is fun.) Note that with the deformer object in "limited" mode, only mesh that's inside the deformer's box is affected. If you want to deform the whole object you can increase the boxsize or set it to unlimited. Link to comment Share on other sites More sharing options...
ZFact Posted September 29, 2006 Author Share Posted September 29, 2006 cheers andrew Link to comment Share on other sites More sharing options...
