Guest nazcaLine Posted September 28, 2006 Share Posted September 28, 2006 how can i turn a word document to a .pdf file? (i have word 97) can anyone help me?? Link to comment Share on other sites More sharing options...
david.jones Posted September 28, 2006 Share Posted September 28, 2006 I've never used this service, but there seem to be many sites on which you can do this for free (as a trial) from common file types, such as .doc files. http://www.google.co.uk/search?hl=en&safe=off&q=pdf+create&meta= Link to comment Share on other sites More sharing options...
carlangas Posted September 29, 2006 Share Posted September 29, 2006 go to the adobe site, they used to have a free service where you could convert up to 5 docuements to pdf files for free. dont know if they still do it, you should check it out. Link to comment Share on other sites More sharing options...
ajvbochove Posted September 29, 2006 Share Posted September 29, 2006 http://www.pdf995.com/download.html the free version will do the trick! You can use it without restrictions. The only thing is that you have the website as pop-up everytime you make a PDF. Link to comment Share on other sites More sharing options...
richmondlu Posted September 29, 2006 Share Posted September 29, 2006 or put the text into photoshop and use the automate command and their is a pdf conversion plugin there. Link to comment Share on other sites More sharing options...
Koper Posted September 29, 2006 Share Posted September 29, 2006 try searching for the pdf printer plugin, this allows you to print any document from any app that allows printint to be printed as a pdf file. If you have the plugin, select print, and where you select which printer to use select the adobe pdf printer, then print and it will ask you where to save the file Link to comment Share on other sites More sharing options...
Justin Hunt Posted October 2, 2006 Share Posted October 2, 2006 Google search for PrimoPDF, its a printer driver to convert most types of document to PDF's which can be read by Adove PDF. Been using it for a while and works well JHV Link to comment Share on other sites More sharing options...
mskin Posted October 2, 2006 Share Posted October 2, 2006 i have used cute pdf for all my programs... works great Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted October 3, 2006 Share Posted October 3, 2006 Thank you guys for your help...very useful indeed. i used the free adobe service for 5 documents and worked fine. BUT...my original document had 8 pages, after conversion, it had 11!!! the original font was bigger than original. Why? I used Garamond. Is there a problem with this font? Link to comment Share on other sites More sharing options...
