Need help
evi85
mostly looks like a post job in photoshop.
lower your perspective to eye level, zoom in and rerender.
take it into photoshop and drop your saturation and bump up your brightness a bit.
acquire some people images with alpha maps. select the alpha path, fill with 100% white. drag on ontop of your first image and set your size and place it in the scene. then add a stroke layer effect of a 1 or two pixel width set to black. (or you can select the current layer transparency and do select--> modify--> border ...1or2 pixels... and fill with black) drop the layer fill% to give the whole person and outline a transparency.
repeat the previous process for all the people and trees and thats it.
depending on how well you know photoshop, what I just said will totally click or leave you completely baffled. It just takes some playing around to get the desired effect your after. but it's always good to play, you might come up with something you like even more.
see attached attack of the 150ft woman version for reference :-)
