mooney102 Posted October 3, 2006 Share Posted October 3, 2006 Can anyone tell me why my vray light, which invisible is checked, is showing up in my mirror reflection as non-invisible? -3d max 8 -vray 1.5 Link to comment Share on other sites More sharing options...
RimasK Posted October 3, 2006 Share Posted October 3, 2006 I have same problem Link to comment Share on other sites More sharing options...
kippu Posted October 3, 2006 Share Posted October 3, 2006 check "affect specular " in the light properties Link to comment Share on other sites More sharing options...
mooney102 Posted October 3, 2006 Author Share Posted October 3, 2006 Thanks kippu, but i have that option checked. my light settings are as follows: under options in the parameters rollout, I have checked invisible, ignore light normals, store with ir map, affect diffuse, and affect specular. Link to comment Share on other sites More sharing options...
BrianKitts Posted October 3, 2006 Share Posted October 3, 2006 check "affect specular " in the light properties it's the other way around, you don't want it to affect specular... to affect it, is to show up. so uncheck "affect specular" it, and your light won't be in the reflections. Link to comment Share on other sites More sharing options...
iancamarillo Posted December 26, 2007 Share Posted December 26, 2007 hmmm... that sucks because the specular is the only think I want affecting my materials. any suggestions??? Link to comment Share on other sites More sharing options...
parker2740 Posted December 27, 2007 Share Posted December 27, 2007 I had the same problem. You can create a box directly in front of the light. Through the object properties for the box, turn off "visible to camera", "cast shadows", "receive shadows" and "visible to reflection" . That should give you the desired effect Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted December 27, 2007 Share Posted December 27, 2007 That's pretty much why V-Ray 1.5 final has a new option called Affect Reflections, for most of us can't afford a light not affecting any specularity... Link to comment Share on other sites More sharing options...
RODRI Posted March 2, 2009 Share Posted March 2, 2009 rick, thks. Link to comment Share on other sites More sharing options...
