biman_b Posted October 6, 2006 Share Posted October 6, 2006 Can anyone help me making realistic grassy moutain texture in max without using plugins. Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 6, 2006 Share Posted October 6, 2006 Grass is one of the hardest things to do in 3D, I have yet to find a good answer to this problem in Max without a plugin. If you have Max 8 you can use Hair to create some nice grass that won't kill your system. You can't really use geometry unless you are willing to put up with the very long render times but even then you will probably run into memory problems. You can try using procedurals to create a map with a lot of variation in it but it's still going to be totally flat. Vray has a nice displacement function that creates very nice grass, so does Final Render to some extent but both of these programs will take some time to learn so unless you have a long deadline that probably won't work. Link to comment Share on other sites More sharing options...
