Microstation Stadium rendering
Dave Bond
Yeah...ok...Blow your socks off huh?
Have you used the software?
No doubt it will do a decent job...BUT,
The rendering engine is old and very slow compared
to the other packages on the market.
Bentley still is using a rehashed integration
of MASTERPIECE into V8.5. Plus, When I call
Bentley support about a problem with global
illumination not meshing correctly, their solution
was simply keep adding more particles until
it renders correctly. Which btw just keeps adding
more time to the final rendering.
This particular render took 6 hours banded across
5 machines. Using low antialias settings and
low raytrace settings. This is unacceptable for the
relatively simple scene that this was.
not to sound harsh, but that for 6hrs across 5 machines?!!! I'm not familiar with Microstation, but for that kind of requirement, you'd be saving in the long run (time and money) by just getting a different renderer. Hell, 3000 for max 6 and it comes with mental ray, or just get viz?
