thickly Posted October 6, 2006 Share Posted October 6, 2006 First - please do not turn this into a bash Maxwell thread, despite all the known issues it has served me quite well. That being said.... The time needed for a completed Maxwell render of interior scenes - which is what I work on mostly - is starting to take its toll on me as the viz demand has increased exponentially in my office. I am considering trying to learn Vray because it seems to perform quite well. Even though the final output in my opinion is still much more CG than Maxwell, it is still quite nice and perfectly acceptable for what I do. I'd like to hear - ideally from users of both - about their experience. - although from the moment you hit the render button until you have a completed image from Maxwell may be longer, is that time offset by doing lighting set-ups and material tweaks in vray? - are the actual render times that much faster on vray, I see some images that look great, but had 6+ hours of rendertime -- or can this be optimized significantly - how long did it take to produce a clean, acceptable, fast image from the time you first started using vray I jumped into Maxwell as soon as I started doing viz work, and the material system makes sense to me, whereas vray and other biased renderers seem to have an endless amount of parameters to adjust, same for lighting set-ups. Would love to hear your thoughts/experiences. Feel free to recommend other software also. Also, keep in mind I have a quad Xeon Woodcrest on order that should be here next week -- I can't wait to see the effect on my Maxwell rendering times. Thanks Link to comment Share on other sites More sharing options...
AJLynn Posted October 6, 2006 Share Posted October 6, 2006 I've used both. Vray more than Maxwell, but I'm getting into Maxwell more lately. First, I think the whole biased/unbiased issue is somewhat overblown and misunderstood. Unbiased just means that the engine is not taking certain steps that most engines take to increase speed at the expense of accuracy. An unbiased renderer does produce an accurate image, but usually one that's been approximated by a biased engine is as good as you need. Vray does have more parameters to work with, but they're not that hard to grasp. It does take longer to set up, and for me the time I spend on set up could be better spent on designing. That's why I'm getting back into Maxwell - I've got a bunch of MXM files, I assign those to a model imported from Sketchup, turn on the sun and sky and hit go. Usually I don't need to do test renders, because the exposure is adjusted on the fly, and I have enough computing power now to get Maxwell to run in reasonable time. Vray has the ability to be very fast, and the material setup doesn't have to take very long - it's pretty much the same as most other software except Maxwell - but there are situations where it can be slow. For example, a project I did this summer had an unusual lighting scenario, and doing it realistically in Vray (using the actual lights) was giving me over 24-hour renders, so I ended up faking it. Maxwell would have actually rendered the scene faster, and I would have spent a lot less time setting it up. They're very different, and each has its uses. Try the Vray demo and maybe get Chris's DVDs, and see what you think. Link to comment Share on other sites More sharing options...
thickly Posted October 6, 2006 Author Share Posted October 6, 2006 thanks Andrew, as always very insightful and helpful. I was actually just over at the Fryrender site -- looks quite promising with ridiculously short rendertimes. I just wish they offered a demo version. I just grabbed the Vray demo, I'll try to play it this weekend -- I've also heard Chris' videos were quite good. would love to hear others experiences. Sean Link to comment Share on other sites More sharing options...
d.sign Posted October 6, 2006 Share Posted October 6, 2006 Yes I saw that fryrender recently and it looks like same thing as maxwell, yet faster! So, now you know that if you got patience you can get same quality in less time for half of the price in preorder, just you will have to wait about the same time as with Maxwell for thing to develop. However, that seem functional enough for some thigns, so perhaps you could try. And about demo, well as you remeber, Maxwell also did not put the demo untill v1.o release. Probably cause of pyracy... But to return to the main question - Maxwell vs. Vray I am Vray user. I use it for production work and it served me well for that matter. I mostly do interiors, so I know what you are talking about. I think that Vray is as clean and fast as one render engine can be. That does not mean that it is best one. But clean and fast result is much easier to get with Vray than with any other render engine I tried. Material setup is mostly simple and lean on the Max workflow for that. Lightning setup ask for some reading between the lines to avoid time consuming situations and sometimes, that means faking. When you got lot of lights you should replace them with luminous geometry (which is simillar to Maxwell) and you get fast results. If you put all the lights you will render for 20 hours or more. All in all, with couple of good tutorials you will get the hang of the lightning in Vray easy. It is one of the easiest really. Though it often ask for tweaking and testing before final shot. But after two dvds by Chris Nichols (not good - the best) you will know all you need to know to make excellent result with Vray. Basically, Vray is all about optimization and they develop it with each new version. That means you can now get same qualitty in less time than with early versions. And they offer several methods to get good quallity/speed ratio (irradiance map, QMC, photon map, light cache...) But all that speeding up actually depends on the actual scene. As for the qualitty of the renders and how far it could go, you should check the work of the Olivier Campaigne, one of the last year AVC winners. But let me put it this way, I would gladly use both Maxwell and Vray if I could. Thing is, I am also kind of bored with Vray, would love to try something new. I did some tests with Maxwell and it is certainly much better for exterior renders and not so slow at that. And you could make couple of boxes look great with that Maxwell phisycall sky. If you can, use the Vray for interior production work and when time alows, take Maxwell and make some kick-ass images with it... Link to comment Share on other sites More sharing options...
thickly Posted October 7, 2006 Author Share Posted October 7, 2006 And you could make couple of boxes look great with that Maxwell phisycall sky. If you can, use the Vray for interior production work and when time alows, take Maxwell and make some kick-ass images with it... Thanks Branko -- you confirmed exactly what I was thinking about using Vray for production work and Maxwell for the true money shots. I have also seen some of the animation work done with Vray and I know that is not possible with Maxwell at this point -- and I would love to start showing the bosses some walk-throughs (they're easily impressed). I know Olivier C. was interviewed on this site, really beautiful images. I've been having a string of luck getting purchases approved at work, so maybe I'll try to put in for VRay and Fryrender pre-order, as well as Chris' DVD's. Might as well keep an aresenal of tools at my disposal. Just downloaded the Vray demo, getting familiar with it will be my project for the weekend. Thanks for your detailed, insightful replies. Link to comment Share on other sites More sharing options...
RyanSpaulding Posted October 7, 2006 Share Posted October 7, 2006 Thanks Branko -- you confirmed exactly what I was thinking about using Vray for production work and Maxwell for the true money shots. I have also seen some of the animation work done with Vray and I know that is not possible with Maxwell at this point -- and I would love to start showing the bosses some walk-throughs (they're easily impressed). I know Olivier C. was interviewed on this site, really beautiful images. I've been having a string of luck getting purchases approved at work, so maybe I'll try to put in for VRay and Fryrender pre-order, as well as Chris' DVD's. Might as well keep an aresenal of tools at my disposal. Just downloaded the Vray demo, getting familiar with it will be my project for the weekend. Thanks for your detailed, insightful replies. Chris' DVDs are the single best thing I've seen. I'm trying to learn VRay amongst having CRAZY deadlines right now with one architect who is using us for design/build, but paying us well for it. I just haven't had time...point being, if they are willing to buy the renderer, the DVDs will increase your production time. WELL worth the money. Link to comment Share on other sites More sharing options...
d.sign Posted October 8, 2006 Share Posted October 8, 2006 Actually, I think you may get the dvds by Chris as speciall add on if you order from VisMasters store, check that before purchasing... Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 9, 2006 Share Posted October 9, 2006 I've been using Maxwell for over a year and I've tried the Vray demo, ease of use is Maxwell's biggest asset over Vray. Since I have very limited experience with Vray I can't comment on how quickly it is to set up but I know that it's going to be a longer process than Maxwell. Other than that I don't think Maxwell has much to offer that Vray can't do. That's not to say that I think Maxwell is worthless but it's single biggest problem is it's speed and NL seems unable to do anything about it. If I were faced with a decision between the two I would definitely go with Vray, but if you can afford both then you will probably find a use for Maxwell when time allows. Link to comment Share on other sites More sharing options...
manta Posted October 9, 2006 Share Posted October 9, 2006 Trying to be as objective as possible, and all things being equal there are a couple points I'de like to make... Maxwell can give you 99% photorealism, and when I say can give, I mean I've seen many examples of this, but I've also seen many that didn't, and I thought to myself "how is that possible" I won't mention any names or examples, but I was really shocked that it could produce something pretty awful really, not photorealistic at all, and they were'nt going for NPR...I tryed Maxwell myself and did not find it easy at all, just as difficult as any other renderer...but in the hands of the right person, it will do amazing things... Vray will give you 90% photorealism, which is more than adequate to portray an idea, if someone needs more information than that, then they're just crazy anyway...I think there is even a way to make vray unbiased, but its going to be very slow... But vray has two very important things that Maxwell dosen't... Displacement mapping and the ability to do animations...there might be a third, but I'm not sure about plugin support, does maxwell support things like dreamscape, RPC's or tree storm ??? Again, I'm not trying to bash Maxwell, just pointing out its limitations, and I don't see how I would be able to choose it based on that, I need a renderer that can do everything Link to comment Share on other sites More sharing options...
Jefferson Grigsby Posted October 9, 2006 Share Posted October 9, 2006 I can see how having an easy to use, simply push a button and get results every time. Unfortunately this type of thinking will hold you back. There is no such thing as a perefct render software. They all need finessing, and they all require post work. If you are not rendering in passes, yet relying on the software to crank out the image for you, then you are waisting time and limiting your work. I have seen work done in Cinema 4D with heavy post work in Photoshop that easily blows away the best Maxwel and Vray Renders. I used to worry that the software would advance to the point where anyone can just hit render and get good results. We are pretty close with Maxwell. However, when you use the software as a crutch to disguise a lack of artistic ability or experience, it will show. Everyone's renderings all start taking on the same character. try to be different and push the envolope. Don't worry so much about which program to use, they are only as good as the user behind them. Also, versatility is the key in this business. If I have to look at one more bedroom or living room scene in an applicants portfolio, I am going to get sick. I would rather hire soemone who can compose and manually light an office tower in the scanline then a person that can purchase a bed off turbo squid, make 4 walls, and hit go on Maxwell. Link to comment Share on other sites More sharing options...
Devin Johnston Posted October 9, 2006 Share Posted October 9, 2006 I have to disagree with you that just because a piece of software makes your job easier that doesn’t mean that you are less of an artist, or that your artistic ability has some how been diminished. I remember hearing a similar argument when GI first hit the scene from people who had traditionally been making renderings using scan line for years. There argument was that you were cheating by using GI and that scan line and manually setting up a scene with omni and spot lights was the only real way to go, that using something else demised the profession and made you less artistic. That wasn't true then and it certainly isn't true now, so if an engine can render out a good image with little or no post I don't see how that is a bad thing. I'm not trying to say that the engine should ever replace the artist, but fewer steps in my opinion while maintaining a high level of quality is a very good thing. Link to comment Share on other sites More sharing options...
AJLynn Posted October 9, 2006 Share Posted October 9, 2006 I'd agree that there are renders I like to do that I'm pretty sure you can't do in Maxwell. But when you want to do a photoreal render with very little prep time and great GI and you really don't have time to put any thought into it, who you gonna call? Link to comment Share on other sites More sharing options...
Sawyer Posted October 9, 2006 Share Posted October 9, 2006 I think the prep time really becomes less of an ordeal in V-ray once you are more familiar with it. I know I spent hours preping scenes and now if I have the time I will play but I can do a really fast set up now and not worry about it. Link to comment Share on other sites More sharing options...
manta Posted October 10, 2006 Share Posted October 10, 2006 I have to disagree with you that just because a piece of software makes your job easier that doesn’t mean that you are less of an artist, or that your artistic ability has some how been diminished. I remember hearing a similar argument when GI first hit the scene from people who had traditionally been making renderings using scan line for years. There argument was that you were cheating by using GI and that scan line and manually setting up a scene with omni and spot lights was the only real way to go, that using something else demised the profession and made you less artistic. That wasn't true then and it certainly isn't true now, so if an engine can render out a good image with little or no post I don't see how that is a bad thing. I'm not trying to say that the engine should ever replace the artist, but fewer steps in my opinion while maintaining a high level of quality is a very good thing. That's totally true, there is alot more to producing a great render than just the render engine, like I was saying, it is VERY possible to make a crappy render with Maxwell, and you wouldn't think so, it cracks me up everytime I saw the splash screen for Studio, and it says "AS EASY AS TAKING A PHOTO" Well I've taken plenty of photos, and its much easier to take photos... I think peoples perceptions of Maxwell are exagerated...it only takes care of one thing, the lighting, and that will get them about 20% of the way to getting a great render... Link to comment Share on other sites More sharing options...
thickly Posted October 10, 2006 Author Share Posted October 10, 2006 first, thanks for all of your intelligent, well thought out replies. If I posted this in the Maxwell section, I think it would have unfortunately disintegrated into a NL bashing party as it seems most topics over there do. I have not been doing viz work for very long, so it was good to hear confirmation from all of the professionals on this board what I had been thinking. - I agree Jefferson, it is not the engine but the person behind it. I'm not looking for the easy way out, but that balance between production-type work that I need to pump out, and the more artistic work/labours-of-love. - AJ/Manta -- I think you nailed it -- for some situations Maxwell is the better choice, but because of some glaring limitations (animation), Vray is the way to go -- so ultimately, having as many tools at your disposal is advised - thanks Branko, Chris' DVD's are included if you purchase Vray from Vismasters I did start to play around with Vray, and must admit I was suprised at the decent results I got with not too much effort. I remember struggling with Scanline forever just to get something even remotely acceptable. I'm sure as I become more familiar with it, it will be useful to me -- I must say though, the amount of parameters does intimidate me. The other thing I would have to get used to, is the way it in which the render clears. In Maxwell, even through all the noise I can usually get a pretty good sense in the first few minutes if I'm going to need to stop and tweak something. I found in Vray, it wasn't till one of the last passes that I noticed an awful hotspot in the render making it unusable - so I had to go back and tweak/re-render. Then there is the multi-light issue, oh how I love multilight! Giving that up would be the hardest part of not using Maxwell for everything. Again, thanks for sharing your thoughts. Sean Link to comment Share on other sites More sharing options...
manta Posted October 10, 2006 Share Posted October 10, 2006 The other thing I would have to get used to, is the way it in which the render clears. In Maxwell, even through all the noise I can usually get a pretty good sense in the first few minutes if I'm going to need to stop and tweak something. I found in Vray, it wasn't till one of the last passes that I noticed an awful hotspot in the render making it unusable - so I had to go back and tweak/re-render. Again, thanks for sharing your thoughts. Sean Hey Sean, You can have that as well with Vray... I set it up as a render preset, and called it preview, All you do is set BOTH your primary and secondary bounces in the Gi rollout to Lightcache, then go to the lightcache rollout, and set that to progressive path tracing, then just hit render, you'll get instant feedback, then just save that as a render preset... It saves me an incredible amount of time... Link to comment Share on other sites More sharing options...
