archkre Posted October 6, 2006 Share Posted October 6, 2006 Despite in Tools/Options/Plot & Publish/Plot Style Table Settings/ I checked "use color dependent plot styles (*.ctb)" as default , when i go to plot something only "*.stb" plot styles appear! Why and how do I fix that? Thank you Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted October 6, 2006 Share Posted October 6, 2006 Never happened to me, but try copying all your objects to another new file. If the original file is corrupt it will work. I always do that when strange things happen in AutoCAD, and works most of the time. Although it really seems that you have an overriden parameter somewhere else. Link to comment Share on other sites More sharing options...
Bhanu Posted October 7, 2006 Share Posted October 7, 2006 If stb is only shown use a system variable called convertpstyles, this will take care converting stb mode to ctb mode. Link to comment Share on other sites More sharing options...
jccloutier Posted October 13, 2006 Share Posted October 13, 2006 your default 'new document' template is set to load an .stb file when you launch autocad. change your template file on the first 'options' tab to use the imperial .ctb file. Link to comment Share on other sites More sharing options...
