Dropping a road onto a hill?
AJLynn
So I've got a couple meshes - one is a hill I made using Terrain, the other a set of roads and footpaths from Sketchup. I don't need anything fancy - the final modeling of this is probably getting done by a consultant - but for our design crit on Monday I'd like to drop the roads and paths onto the hill so the geometry conforms. Anybody got a quick-and-dirty trick for that that I can do in Max or Viz?
Two quick ideas--
Use the SU geometry for a boolean mash-up with your terrain mesh
render a plan view of the SU stuff and use it as a texture map layed over your terrain.
OK, three--
Have the SU stuff in place ever-so-slightly ABOVE the terrain, not casting a shadow onto the terrain. From a distance it'll look about right.
Thanks. Actually, Ernest's post reminded me to try Sandbox - I never used it before, but it follows logically from planar UVW mapping :) But, damn, this is slow - I've got the terrain imported and it's maybe 50,000 polys, and this drape tool is slooooow even in the MBP.
Go Tigers.
I would re-model the terrain in Sketch Up and then try the Sandbox tools. It should work without a problem. Otherwise, have you tried using the ShapeMerge Compound object in 3dsmax? It is a little bit tricky but it has worked for me in the past.
I did try making the terrain in Sketchup with Sandbox from contours and it was ridiculous - it took forever and the geometry was huge - but the Max Terrain command took about 5 seconds and it has the every-4th-point mode, so it ended up being low poly. Much as I love Sketchup, it's not cut out for geometry like this, where Max deals much better. I'll try Brian's method tomorrow. Thanks Brian, you are a true ass saver.
Once I get this part done, and it looks like it won't take more than a few minutes, I've already got my MXMs in place and I'll just run off a bunch of Maxwell renders. A few months ago I wouldn't have believed I'd ever sing the praises of Maxwell and Intel, but for this kind of work you can't beat it - set up some cameras in places with a lot of sunlight, dedicate an overclocked Core2 for a weekend and let it do the work for you.
