Esteban Gonzalez Posted October 7, 2006 Share Posted October 7, 2006 Hey ppl...... i having problem with C4d 9.5 and P4 D... (3.0ghz, 2gb Ram, 256mb Video Dell 9150) now my laptop (Centrino 1.7. 1gb 128mb video) is faster than the P4D... is the config for the image is large one (6640x4843 pixels) and radiosity at 70%of Strengh and Accuracy with no efects and no caustic either.... in the P4D is like almos 3 hours and in the laptop is 1:15.... .... thanks. Esteban Link to comment Share on other sites More sharing options...
srek Posted October 7, 2006 Share Posted October 7, 2006 Sounds like your P4 has some kind of configuration problem. A Centrino is a good deal faster as a P4 given the same clock speed and a 1.7 GHz Centrino is nearly en par with a 3 GHz P4, but it's nowhere near as much faster as your resulty imply. Cheers Björn Link to comment Share on other sites More sharing options...
STRAT Posted October 7, 2006 Share Posted October 7, 2006 Srek - are there any pc configuration proceedures we can go through for c4d to make sure we're running optimally? it'd be nice to know we're running up to speed. Link to comment Share on other sites More sharing options...
srek Posted October 7, 2006 Share Posted October 7, 2006 None that i'm aware of. As i said, only a messed up configuration could account for that kind of difference and there is no general rule or way to determine if something is not ok. In general each and every software gadget running parallel to CINEMA will eat up CPU time, so disabeling everything you don't realy need is a good idea. The Task Manager can give you a hint if something is eating CPU time beside CINEMA. Cheers Björn Link to comment Share on other sites More sharing options...
STRAT Posted October 7, 2006 Share Posted October 7, 2006 i personally find that keeping the task manager open and minimised when using c4d gives even great stability. Link to comment Share on other sites More sharing options...
AJLynn Posted October 7, 2006 Share Posted October 7, 2006 Esteban- Did you use Task Manager to monitor the CPU usage while rendering? The laptop should be a bit slower than one of the Pentium D's cores, with both the D should be about twice as fast. While rendering, you should see both cores working at full and Cinema should be at well over 90% CPU utilization. If it is, then you need to debug a Cinema config problem... Link to comment Share on other sites More sharing options...
Esteban Gonzalez Posted October 8, 2006 Author Share Posted October 8, 2006 i always do the task manager thing when im using C4D... it works sometimes... but the thing is.... my desktop is a dual core 3.0. and 2gb of Ram. and the laptop is a simple centrino 1.7... and 1g.. how is posible that the centrino goes faster that a dual core..... Link to comment Share on other sites More sharing options...
manta Posted October 8, 2006 Share Posted October 8, 2006 because basically the P4D has never been a great performer, its based on an inferior technolgy...is your centrino a core duo or a single Pentium M... Link to comment Share on other sites More sharing options...
