ZFact Posted October 10, 2006 Share Posted October 10, 2006 Hi all; I just brought strat one step closer to his fame and fortune last night by purchasing his famous animated water shader. Im wondering is there anyway of making this water animated when rendering in final render 2? Nice shaders Strat at a good price... a big well done. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 10, 2006 Share Posted October 10, 2006 Im wondering is there anyway of making this water animated when rendering in final render 2? Hope SP2 is released soon. fr2 cannot render animated noise, it's a bug. You can move the texture, and animate it that way, but it's not the same. Link to comment Share on other sites More sharing options...
STRAT Posted October 11, 2006 Share Posted October 11, 2006 cheers m8y just subtly use the animated map that comes with the shaders instead of animated noise. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Share Posted October 11, 2006 cheers m8y just subtly use the animated map that comes with the shaders instead of animated noise. Im a bit lost as usual Strat. Can you elborate a bit on this please Cheers Link to comment Share on other sites More sharing options...
STRAT Posted October 11, 2006 Share Posted October 11, 2006 if you purchase the shaders they come with a looping animated texture map of ripples. this can be used in place of animated noise in most cases. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Share Posted October 11, 2006 if you purchase the shaders they come with a looping animated texture map of ripples. this can be used in place of animated noise in most cases. and do you place the animated ripples into the bump channel in a cinema material or into a final render shader tree setup... if its the later can you guide me thru it. Link to comment Share on other sites More sharing options...
STRAT Posted October 11, 2006 Share Posted October 11, 2006 generally in the bump channel. although how you set it up in FR i cant comment on as i dont use it. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Share Posted October 11, 2006 generally in the bump channel. although how you set it up in FR i cant comment on as i dont use it. i have a render on cooking at the minute so cant test it.... anyone know if i load a animated water loop into the bump in cinema will it animate when rendered in FR2. Cheers Link to comment Share on other sites More sharing options...
