pauldoherty Posted October 11, 2006 Share Posted October 11, 2006 anyone know where i can purchase some animated clouds which will animate in Final Render 2. Cheers Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 pauldoherty said: anyone know where i can purchase some animated clouds which will animate in Final Render 2. I don't. But the technique would be to use a map on a sphere. But why buy maps when you can make your own? The C4D SKY module does fantastic work (noise-based, not photo) and can be animated, and baked to a spherical map. Link to comment Share on other sites More sharing options...
Arnold Sher Posted October 11, 2006 Share Posted October 11, 2006 try http://www.doschdesign.com and search for animated sky... That should do it Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Author Share Posted October 11, 2006 Ernest Burden said: I don't. But the technique would be to use a map on a sphere. But why buy maps when you can make your own? The C4D SKY module does fantastic work (noise-based, not photo) and can be animated, and baked to a spherical map. Baking isnt something i know much about let alone baking an animated sky. How do i create a noise based animated sky and then bake the noise based sky onto a spherical map? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 pauldoherty said: Baking isnt something i know much about let alone baking an animated sky. How do i create a noise based animated sky and then bake the noise based sky onto a spherical map? You would use the built-in SKY function (C4D 9.5 and up), then use a pre-set object in the browse objects menu for just that function--baking a sky to a sphere. I'm not going into detail unless I know you will be going that route. The suggestion of buying sky maps is perfectly fine, too. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Author Share Posted October 11, 2006 Ernest Burden said: You would use the built-in SKY function (C4D 9.5 and up), then use a pre-set object in the browse objects menu for just that function--baking a sky to a sphere. I'm not going into detail unless I know you will be going that route. The suggestion of buying sky maps is perfectly fine, too. Ernest; I would like to go down this route for definite and would appreciate any help you could give me, but if its to lengthy a process for you to describe here on the forum perhaps you could point me in the direction of a good tutorial for this topic. Thanks either way Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 First open C4D and try some stock skies out. Look in the plugins pulldown for the sky system. Find a sky that you like. I think there is a tutorial, maybe its a video, on the 9.5 instalation discs. The baking is really easy, and would be the last step, so get the sky setup the way you like rendering with C4D. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Author Share Posted October 11, 2006 Ernest Burden said: First open C4D and try some stock skies out. Look in the plugins pulldown for the sky system. Find a sky that you like. I think there is a tutorial, maybe its a video, on the 9.5 instalation discs. The baking is really easy, and would be the last step, so get the sky setup the way you like rendering with C4D. I took the tutorial on texture baking and now understand the concept of it. I think the idea is to save on render times which i have grasped when creating still shots but im still confused how this works when creating animations. To create the baked texture for the sky dome... do i select the preset sky to my liking then select a sphere primitve object then select bake object from the render settings. Once this is done do i locate and apply the baked texture back onto the sphere? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 pauldoherty said: To create the baked texture for the sky dome... do i select the preset sky to my liking then select a sphere primitve object then select bake object from the render settings. Once this is done do i locate and apply the baked texture back onto the sphere? First you play with some skies, decide if they're what you want, get the hang of animating one. Link to comment Share on other sites More sharing options...
NOOXY Posted October 11, 2006 Share Posted October 11, 2006 I haven't grasp the concept of baking yet and heard it does wonders for your render times.. i think a skyanimation is a simple yet effective way to create great effects to renderings, I'll love to learn how this is done as well...anyfeedback for us please post:) Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 I figured I should refresh my memory before sending you down a bad path. Yep, it works as I thought. http://www.oreally.com/temp/skyanimtestReflection.mov I took one of the presets and just set one parameter to animate, then baked it to a QT file. In Cinema go to the 'window' pulldown and select the Content Browser and you will find all the SKY stuff plus the baker file under 'Misc'. Link to comment Share on other sites More sharing options...
STRAT Posted October 11, 2006 Share Posted October 11, 2006 yup, as EB says, the sky shader in 9.5 and above really is something special. and it's a bucket load of fun playing with the settings to experiment and familierise urself with it. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 STRAT said: yup, as EB says, the sky shader in 9.5 and above really is something special It sure is. Is there anything like it in Max? Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Author Share Posted October 11, 2006 Ernest Burden said: I figured I should refresh my memory before sending you down a bad path. Yep, it works as I thought. http://www.oreally.com/temp/skyanimtestReflection.mov I took one of the presets and just set one parameter to animate, then baked it to a QT file. In Cinema go to the 'window' pulldown and select the Content Browser and you will find all the SKY stuff plus the baker file under 'Misc'. Ok iv animated the sky in cinema... just like you said... one click of a button.. easy.... Now its the baking thing again. How do i apply that sky animation to the bake environment and bake it...? Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 pauldoherty said: Ok iv animated the sky in cinema... just like you said... one click of a button.. easy.... Now its the baking thing again. How do i apply that sky animation to the bake environment and bake it...? You could not possibly have had enough fun yet playing with SKY settings. You aren't yet worthy of baking. As I told you... In the Contents Browser window you will find a folder called Misc, and in it a preset for 'environment baking', load that into a file with just the sky that you want to use. You have a choice of baking to a sphere or a half-dome. Click on the baker tag (blue wavy thing) and open up the options, details, etc parts. The top is where you choose what sort of output to do (I chose QTmovie with Sorrenson3 compression) and a size in pixels (start with something like 1000 x 500 or smaller to test the process) don't forget to name your output anim by the way. Below that is a small square with a button that reads 'Bake'. Click it. There are things to adjust and try out in the baker dialogs, but I've covered most of it. The result will be a rendered file that can be mapped onto a sphere in the lum. channel, turn off generate GI (also in your Final Render tags) and shadow recieving and casting. Remember that when you bake to have GI and shadows turned OFF, and all bounces set to 1. That is the basic version. Link to comment Share on other sites More sharing options...
pauldoherty Posted October 11, 2006 Author Share Posted October 11, 2006 Ernest Burden said: You could not possibly have had enough fun yet playing with SKY settings. You aren't yet worthy of baking. As I told you... In the Contents Browser window you will find a folder called Misc, and in it a preset for 'environment baking', load that into a file with just the sky that you want to use. You have a choice of baking to a sphere or a half-dome. Click on the baker tag (blue wavy thing) and open up the options, details, etc parts. The top is where you choose what sort of output to do (I chose QTmovie with Sorrenson3 compression) and a size in pixels (start with something like 1000 x 500 or smaller to test the process) don't forget to name your output anim by the way. Below that is a small square with a button that reads 'Bake'. Click it. There are things to adjust and try out in the baker dialogs, but I've covered most of it. The result will be a rendered file that can be mapped onto a sphere in the lum. channel, turn off generate GI (also in your Final Render tags) and shadow recieving and casting. Remember that when you bake to have GI and shadows turned OFF, and all bounces set to 1. That is the basic version. Ok... Thanks a million.... i'll play around with that now the rest of the night and make myself more worthy for my speel of questions in the morning. i have an animated sky on cooking at the minute... groovy. Link to comment Share on other sites More sharing options...
manta Posted October 11, 2006 Share Posted October 11, 2006 Ernest Burden said: It sure is. Is there anything like it in Max? Yes, its called Dreamscape, its an increadible plugin, but it also costs like 500 bucks...here's the link http://www.afterworks.com/DreamScape.asp Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 11, 2006 Share Posted October 11, 2006 manta said: Yes, its called Dreamscape Wow, it looks...tiny. It looks great. C4D's SKY doesn't have seascapes. The clouds are based on noise patterns, and it looks like that plugin is, too. It's the right way to go, I think. Thanks for pointing that out! Link to comment Share on other sites More sharing options...
manta Posted October 12, 2006 Share Posted October 12, 2006 It does a great job with skys, but the oceans are the coolest, did you see the animations on that site... http://www.afterworks.com/animations.asp Link to comment Share on other sites More sharing options...
ZFact Posted October 12, 2006 Share Posted October 12, 2006 Quote There are things to adjust and try out in the baker dialogs, but I've covered most of it. The result will be a rendered file that can be mapped onto a sphere in the lum. channel, turn off generate GI (also in your Final Render tags) and shadow recieving and casting. Remember that when you bake to have GI and shadows turned OFF, and all bounces set to 1. do you just map the rendered animated file the same way you map a sill texture Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 12, 2006 Share Posted October 12, 2006 ZFact said: do you just map the rendered animated file the same way you map a sill texture Yes Link to comment Share on other sites More sharing options...
ZFact Posted October 12, 2006 Share Posted October 12, 2006 Ernest Burden said: Yes Somethings wrong then... iv played the animation in QT... works a treat but when i load it in as a texture... the texture preview shows just black!!! Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 12, 2006 Share Posted October 12, 2006 ZFact said: when i load it in as a texture... the texture preview shows just black!!! There's a setting in C4D regarding that, and I forget where it is. I'm sure someone will tell us about it. But right in the material's panel you can check whether to see animated previews. Anyway, map it onto a sphere, set the C4D frame count to match your QT and simply render it out to test the procedure. Link to comment Share on other sites More sharing options...
ZFact Posted October 12, 2006 Share Posted October 12, 2006 Quote Anyway, map it onto a sphere, set the C4D frame count to match your QT and simply render it out to test the procedure Iv mapped it onto a sphere but when i render it out to animate the sky remains static! Any ides what im doing wrong Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 12, 2006 Share Posted October 12, 2006 ZFact said: Iv mapped it onto a sphere but when i render it out to animate the sky remains static! Any ides what im doing wrong No. Earlier I tried the same thing myself, it worked. I put the QT in the luminence channel, turned all others off. Check on the last page of the material panel, there is a checkbox for animate texture, though I'm pretty sure that refers just to the previews in the panels. But maybe not. There's also some settings related to the animated texture in the channel, click on the tiny preview to get to those settings, maybe you missed something there. Not only will you get animated output, you should see your texture update on the sphere in the viewport as you move the time slider. Or, if you can't get it fairly quickly, post the file with just your sphere and material, I'll drop in my own QT, but we can check your settings for you. It would only take a few minutes Link to comment Share on other sites More sharing options...
