helenistikyay Posted October 12, 2006 Share Posted October 12, 2006 i have a problem and need help these are my images in v-ray render as you see there is no background but black Link to comment Share on other sites More sharing options...
JamesTaylor Posted October 12, 2006 Share Posted October 12, 2006 it'll be down to your max refraction / reflection settings and their exit colour. play around with the values and see how it affects your test image Link to comment Share on other sites More sharing options...
helenistikyay Posted October 12, 2006 Author Share Posted October 12, 2006 i am sorry i ve tried all combinations but it didn't work what shall i do? Link to comment Share on other sites More sharing options...
helenistikyay Posted October 12, 2006 Author Share Posted October 12, 2006 this is my problem on the left a v-ray material turned into glass on the right an architectural material (Doors & Windows.Glazing.Glass.Clear) you can see can you help me what is the problem? Link to comment Share on other sites More sharing options...
BrianKitts Posted October 12, 2006 Share Posted October 12, 2006 my guess is it would have something to do with your background, not the exit color. do you have a spherical environment map for a background or is it just a flat map? It's kinda confusing me, cause if you are using a flat map, the reflection would be black, but the background should appear correct, yet that black is so strong. try getting rid of your background map and make your background just a solid color. if that renders correctly, then you just need a better background map. Link to comment Share on other sites More sharing options...
kippu Posted October 12, 2006 Share Posted October 12, 2006 post the material settings pls Link to comment Share on other sites More sharing options...
olbo Posted October 12, 2006 Share Posted October 12, 2006 Heya Ismail, do you use exponential color mapping on this scene and do you have "Affect background" checked in the Color mapping rollout? If so, ... uncheck "Affect background". I could be wrong but I do recall some other threads with this kinda problem. Hope this will help ya. ;o) take care Oleg Link to comment Share on other sites More sharing options...
helenistikyay Posted October 13, 2006 Author Share Posted October 13, 2006 thanks for your help but ... these are my settings and render. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted October 13, 2006 Share Posted October 13, 2006 Uncheck the Reflection/refaction environments override in the Vray Environment section Link to comment Share on other sites More sharing options...
helenistikyay Posted October 13, 2006 Author Share Posted October 13, 2006 thank you very much Trevor Tizard and everyone else the problem was Reflection/refaction environments override in the Vray Environment section. Link to comment Share on other sites More sharing options...
