BrianKitts Posted October 13, 2006 Share Posted October 13, 2006 I'm working on a sightplan that has some slight elevational changes. everythings been going well but now when I try to edit the mesh for my grass object, the pivot alignment for the whole object is aligned properly, but when selecting a single vertex the pivot is all funky. I've tried the higherarchy tab for adjusting the pivots but it doesn't seem to affect a single vertice. any ideas? (see attached) Link to comment Share on other sites More sharing options...
BrianKitts Posted October 13, 2006 Author Share Posted October 13, 2006 ADDON: okay looks like I've screwed the whole scene somehow. even when I create new objects and do an edit mesh the gizmos for the vertexs are all jacked up as before..... anyone encountered this or know the fix to realign this??? :-( Link to comment Share on other sites More sharing options...
chutti Posted October 13, 2006 Share Posted October 13, 2006 Ummm...not sure about this you can go to the Hierarchy tab and press The Reset Pivot Button while any vertex is selected. also check your Reference coordinate system on the top of youe tool bar if its set to Default 'View' or changed to Local, Gimbal, Grid etc..... good luck!! Link to comment Share on other sites More sharing options...
BrianKitts Posted October 13, 2006 Author Share Posted October 13, 2006 GENIUS! didn't even know about the refernece coordinate system was up there. that was it..... it was set to view, I put it back to world and all is good again. thx chutti Link to comment Share on other sites More sharing options...
