Woody Posted October 13, 2006 Share Posted October 13, 2006 Hi Guys, Sorry if this has already been covered but I did search and couldn’t find anything. As you’ll see from the small previews I am getting splodges over my walls, can someone tell me if my settings are too low and if so what they’d recommend? (I am still on Vray 1.49) I’ve used the noise threshold in the past to try and remove this problem but since the default changed I’ve no idea what’s a sensible number to set it at? Plus I can’t remember if it is the “Adaptive Subdivision Images Sampler” or the “Vray QMC Sampler” that I should be changing? Thanks! Link to comment Share on other sites More sharing options...
Tommy L Posted October 13, 2006 Share Posted October 13, 2006 Hello woody, hows it going? You could try lowering the interp. samples. This blends the shadow samples more. Try it on 15 and see what that does. You will have to re-calculate the irr map (looks like youre rendering from a saved file). Dont know about the light cache (i take it thats second bounce) because it has different parameters in 1.46.15 which im using. Have you noticed much improvement between 1.46 and 1.49? Link to comment Share on other sites More sharing options...
Woody Posted October 13, 2006 Author Share Posted October 13, 2006 Cheers Tom, i'll give it a go! I am good mate just plodding along, thinking of moving to London at the begining of next year. Hope you're ok mate? Any more advice welcome. Link to comment Share on other sites More sharing options...
Tommy L Posted October 16, 2006 Share Posted October 16, 2006 yes im ok, back in chicago after 3 months in UK sorting my visa out. Its a rockin city, if you ever feel like getting out of england i know a couple of guys in the business out here that may be able to fix you up. Link to comment Share on other sites More sharing options...
Woody Posted October 30, 2006 Author Share Posted October 30, 2006 Does anyone else know what could be causing the patchyness??? Link to comment Share on other sites More sharing options...
