Tired Of Rpc's
gkoumout
okay so ive decided im tired of using rpcs, they slow down my render time considerably, they are difficult to shade, and they dont give me a chance to really be artistic and explore VIZ even more. so, first off, if you think i am wrong in these statements i really would be glad to hear why, maybe im doing something wrong.
secondly, if i stop using rpc's, how can i effectively and efficiently create my own images to take the place of these rpc's...i am studying to be a landscape architect, so lets say i need to make trees, groundcover, shrubs etc...if you have any information whatsoever that would be awesome....i just dont want to have my work be the same as everyone elses...im sure you can all agree with that. thanks!!!
yeah I know how you feel, check out the xfrog libraries, the onyx tree libraries and recently the evermotion guys have been making tree and plant models.
My personal opinion is that the xfrog models are the best but they are pretty heavy on the polycount.
just realising now that you want to create your own models.......try the xfrog software, awesome for making custom trees and plants.
Crossing 2 plans with the same tree image on it will work 90% of the time for stuff thats not right in your face and even stuff thats in your face if the lighting is done right you wont realise that its not a model.
But these require a projector map and i would prefer to use models if needed for close up
SSSSSOOOOOOOO Tired...
They are good for what they do, just as long as you like what they do....
Have you looked at the pricing structure? Based on the concept of being fully licensed they whole library is something like $15K.
I used to have 3 Art-Render Pures, 5 RD 2000s, and an RD3000. It was hundreds of processing cores. It was like owning the USS Ronald Reagan. Massive horsepower and virtually unlimited cycles.
In the Renderpipe software each RPC had to be individually ripped, processed, and sent over. It nuked the performance down to the speed of the host PC. As a result, I sold them all off. I couldn't find a better solution to RPCs.
Why doesn't somebody write a plugin that creates MAX 'primatives' that can be trees or ground over? Maybe a person or two also -- really, no matter what race ethnicity or gender, do we really look that different?
Imagine a $499 plugin that would do it! Keep dreaming I guess...
so i was on the xfrog website and noticed they have a product thats sole purpose is to reduce faces and polygons from an object to improve rendering time etc...
does this mean without the software, the render time will be the same as an RPC's time in VIZ
also, im not sure i understood all of the last couple posts about bringing xfrog objects to other application. so is what youre saying that you need another piece of software to bring an xfrog tree for example into another program like VIZ
sorry for the lack of understanding...just talkin to a rookie thats all
No you don't need another piece of software......Xfrog has some good max (or viz) plugins. Basically you can export out of Xfrog in .3ds (dwg, dxf etc etc) or you can use the plugin and import .xfrog files into max (and viz I think).
Xfrog tune is indeed a polygon reduction tool but if your creating trees in Xfrog, you won't need it. You have complete control over how many polygons are in every part your tree, branch and trunk control, leaf control....everything.
On their website, check out their pre made libraries (pdf documents). All of those were made in Xfrog (some very impressive stuff) and give Stewart Mcsherry an e-mail (default contact e-mail), he's a great guy and will be more than happy to answer any of your questions.
Personally, i like select RPCs and find (select) RPCs indispensible. Why they are not all to the same level of quality I don't know. I love Onyx trees but if i need a forest of trees and dont want to spend hours rendering billions of polygons, i use RPCs. I simply disable shadows, place a Generic Oak from the (AEC Extended menu) at the center of each RPC tree, turn off the Visible to Render option (so that it casts shadows for the RPCs) and the result is very acceptable. All the trees in this animation were RPCs and they add only seconds to each frame. http://3das.com/images/gallery/movies/PizzeriaUno.mov
  • 3 weeks later...
If you get RPC CreatorPro you can make your own RPCs out of your Xfrog/ Onyx trees. works well and saves on the poly count.
Because you can use higher res images for your created RPCs they look much better up close. Although for very close trees still use geomerty.
JHV
I've also found you can exclude the x-frog models from the GI calculations....its hardly noticeable in quality , but a massive saving in rendering time
