drvox Posted October 19, 2006 Share Posted October 19, 2006 Hi all I've setting up a interior scene with vray...The lightning wasn't perfect, but it was acceptable in my pc...but when I send it to other people everyone says it is too dark... I wonder if my pc might have some problem in the screen settings... thanks a lot Link to comment Share on other sites More sharing options...
martin walker Posted October 19, 2006 Share Posted October 19, 2006 possibly....or you arent "saving gamma" settings in your max file ? Link to comment Share on other sites More sharing options...
drvox Posted October 19, 2006 Author Share Posted October 19, 2006 How can I do it? Link to comment Share on other sites More sharing options...
martin walker Posted October 19, 2006 Share Posted October 19, 2006 Customise > Preferences > Gamma and LUT tab though if you dont know what it is, I doubt you have changed the Gamma settings in the first place, so problem might be else where Link to comment Share on other sites More sharing options...
drapp@frontiernet.net Posted October 19, 2006 Share Posted October 19, 2006 Another possibility is that the other PCs have a different version of the same image. I've had that before. It can cause flickering or lighting problems if you are deriving lighting from the image. Try manually deleting the image off the other computers. Also - if you are using a CRT monitor - and you have the Adobe Gamma control pannel - run that and see if it fixes things. Good luck, Dave Link to comment Share on other sites More sharing options...
BrianKitts Posted October 19, 2006 Share Posted October 19, 2006 when you say "send it to someone else's machine" are you referring to a rendering process either a farm or ditributive, or are you referring to having a finsihed image.... jpgs or likewise, and simply viewing it on someone else's screen? It's always fun when one of our designers tell us it's too dark or our colors are wrong and then it turns out their monitor settings are completey messed up. Link to comment Share on other sites More sharing options...
drapp@frontiernet.net Posted October 23, 2006 Share Posted October 23, 2006 Sorry, I wasn't specific - I was deliriousy tired at the time. I was refering to when you use a render farm to render your animation. Sometimes - for reasons I don't want to admit or don't understand - one or more of the machines on the render farm get a newer version of one of the texture images. then 1 out of X frames will have a different map. If that is the case just delete all the images from that machine and the next time you send the job to render - make sure that "include images" is checked in the network render dialog box. Dave Link to comment Share on other sites More sharing options...
