mm224 Posted October 19, 2006 Share Posted October 19, 2006 I've been working on a bathroom scene using 3dmax 8 and Vray 1.47 with distributed rendering. I've posted 2 images: one test that was rendered on a low resolution around 300x 400 and an image at 4096 x 3112. The large image rendered with dark squares. What confuses me is that the smaller image rendered fine. I know it's a problem with the dr, but im not sure how to fix it. Any comments would be appreciated. Thanks. mm224 Link to comment Share on other sites More sharing options...
alfienoakes Posted October 19, 2006 Share Posted October 19, 2006 looks like the IR map isn't being calc'd properly for one of the machines. How many machines are you using for your DR? Also, are you using a precalc'd IR map, I would imagine not, but worth asking. You can see geometry behind the "blackness", so it does look like the IR is not working on that portion. Link to comment Share on other sites More sharing options...
mm224 Posted October 19, 2006 Author Share Posted October 19, 2006 Im using 8 machines on a low preset...render time was a little over 12 hours. I don't understand how it could work on a smaller image and not on the larger. Any ideas? Thanks. Link to comment Share on other sites More sharing options...
manta Posted October 20, 2006 Share Posted October 20, 2006 Are you using QMC for secondary ?? Link to comment Share on other sites More sharing options...
alfienoakes Posted October 20, 2006 Share Posted October 20, 2006 Just as an aside, 12 hours does seem very long, especially on a low preset. And thats with the render time effectively being cut down to an 1/8 th of what it should be. DR should speed things up.. I would think no more than an hour for a complex scene like yours.. Do you have some high glossy settings in there or something..? Andy Link to comment Share on other sites More sharing options...
