thickly Posted October 19, 2006 Share Posted October 19, 2006 Can anyone tell me how to universally set line thickness to 0". I usually just take ACAD drawings, clean them up a bit and import into 3ds max so I can extrude them up. I keep getting drawings from colleagues though with different line thickness, and even some where the start of the a line might be at 0" in the z-axis, but end at 4" in the z-axis -- and its really screwing me up when importing the drawings. Is there anyway to take a drawing and easily set it so all lines are at 0" on the z-axis and have 0" thickness? Thanks! Link to comment Share on other sites More sharing options...
vizwhiz Posted October 19, 2006 Share Posted October 19, 2006 hi There To set elevations To 0 use 'flatten.lsp' select: ALL Then run The 'flatten.lsp' To set plines width To 0, well do This ; ETC-PLNS.LSP. ; Copyright © 1988 by Gary D. Lipp (setq pre-plw 0.0) (defun C:PLW (/ ss i lth en et v osm snm) (setq osm (getvar "OSMODE") snm (getvar "SNAPMODE") ) (setvar "CMDECHO" 0) (setvar "OSMODE" 0) (setvar "SNAPMODE" 0) (prompt " PLineWidth... also changes Lines and Arcs to wide Plines.") (prompt (strcat "\n Enter, or show, the new Pline width: ")) (setq v (getdist)) (if (setq ss (ssget)) (progn (setq i 0 lth (sslength ss)) (if (= nil v) (setq v pre-plw) (setq pre-plw v) ) ; END OF IF (while ( (setq et (cdr (assoc 0 (entget (setq en (ssname ss i)))))) (cond ((= et "LWPOLYLINE") (command ".PEDIT" en "W" v "X")) ((= et "ARC" ) (command ".PEDIT" en "Y" "W" v "x")) ((= et "LINE" ) (command ".PEDIT" en "Y" "W" v "x")) ) ; END COND. (prompt ".") (setq i (1+ i)) ) ) ) ; END OF WHILE i (setvar "OSMODE" osm) (setvar "SNAPMODE" snm) (setvar "CMDECHO" 1) (prompt "Done.\n") (strcat (rtos pre-plw) " is now the width of the Plines.") ) ** select: ALL The lsp routine will filter out what can be modified ** i may have renamed The lsp file but it is/was written by its original author, not me ** hope This helps i use This pline width modifier ALL The Time, works well Too There are 'other' pline edit/modifiers Too. from The same author PLC, PLineClose... Select the Plines to Close:" PLD, PLineFitDecurve... Select the Plines to Decurve:" PLF, PLineFitCurve... Select the Plines to Fit Curve:" PLO, PLineOpen... Select the Plines to Open:" PLS, PLineFitSpline... Select the Plines to Spline Fit:" very useful PLX, polyline explode These Two i use ALL The Time PLJ, PLineJoin... Select the Lines, Arcs, and Plines to Join:" PLW, PLineWidth... also changes Lines and Arcs to wide Plines." PLJ can work on multiple selections at The same Time, very handy Thanks Randy Link to comment Share on other sites More sharing options...
jccloutier Posted October 19, 2006 Share Posted October 19, 2006 type "ch" to open properties dialogue select everything change pull down on top of design/properties tab to show only plines change thickness to 0" repeat with lines, arcs etc Link to comment Share on other sites More sharing options...
thickly Posted October 19, 2006 Author Share Posted October 19, 2006 sorry Randy, you lost me at "hi there" Jeremy, thanks for the help, that was exactly what I needed. I never even thought to use that drop down menu in the properties dialog. Thanks, Sean Link to comment Share on other sites More sharing options...
jccloutier Posted October 19, 2006 Share Posted October 19, 2006 right on my brother from another mother. Link to comment Share on other sites More sharing options...
