VRay 1.5 RC3 Enterprise Upgrade
Parker1
Two co-workers, an IT staff member, and myself just spent several hours upgrading almost 50+ machines from 1.47 to 1.5 RC2. Does anyone know if there is a way to push the upgrade from 1.5 RC2 to 1.5 RC3 using a batch script or command line? I just can not imagine having to go to every computer again to re-run the new installer for RC3. Any help would be appreciated.
Heya Brian,
as far was I do recall you could install VRay to an UNC path and then
include it in the plugin.ini file, then copy the needed files that will be
installed to the maxroot dir to another UNC path and put this path
into your env. variable. If I'm not wrong you'll be set. ;o)
take care
Oleg
