kwerch Posted October 20, 2006 Share Posted October 20, 2006 Hi- Is there a way to scatter a vray proxy? thx- karl Link to comment Share on other sites More sharing options...
Visual Henry Posted October 21, 2006 Share Posted October 21, 2006 You may want to try GroundWiz Planter. It helps place proxy objects. http://www.gugila.com/groundwiz_planter.html You can use GroundWiz Lite, free version, and also download some proxy example file here: http://www.gugila.com/downloads.html Link to comment Share on other sites More sharing options...
kwerch Posted October 21, 2006 Author Share Posted October 21, 2006 Thx Henrik- I've downloaded the lite version and sample files- will take a look this weekend- cheers! Link to comment Share on other sites More sharing options...
jow Posted October 22, 2006 Share Posted October 22, 2006 There is also a free scatter tool that supports proxies at- http://www.maxplugins.de/ Just do a search for "scatter";) Link to comment Share on other sites More sharing options...
fobus Posted June 27, 2008 Share Posted June 27, 2008 (edited) You can use plugin by Gugila - GroundViz. But it too slow to generate huge amounts of proxies. www-gugila-com Or You can use new plugin by iCube Visualization called VrayScatter. community.livejournal.com/ru_icube/ Edited June 27, 2008 by fobus Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 27, 2008 Share Posted June 27, 2008 http://www.scriptspot.com/3ds-max/advanced-painter Download it, learn it, use it… Link to comment Share on other sites More sharing options...
fobus Posted June 28, 2008 Share Posted June 28, 2008 Advanced painter is cool script? but it's not useful for huge amounts of objects. Link to comment Share on other sites More sharing options...
Claudio Branch Posted June 28, 2008 Share Posted June 28, 2008 You might also take a look at the new Forest Pro plug-in. Link to comment Share on other sites More sharing options...
fobus Posted June 30, 2008 Share Posted June 30, 2008 VRayScatter is going to be released: icubeviz.com/services/VRayScatter/ Link to comment Share on other sites More sharing options...
Trick Posted June 30, 2008 Share Posted June 30, 2008 You can use plugin by Gugila - GroundViz. But it too slow to generate huge amounts of proxies... No problems here, but if you want real speed you just switch of collision detection and it places millions of instances in seconds. VRayScatter may be better for multimillion proxies in huge area covering projects, but if you want precise control over placement I think GroundWiz is far more advanced !! It only could use some better memory managment at rendertime so it can render those million instances within ONE planter !!! Link to comment Share on other sites More sharing options...
fobus Posted June 30, 2008 Share Posted June 30, 2008 memory management and rendertime geometry generation (on demand) is the main difference between this products. VRayScatter can generate 100k objects in near realtime. It can generate 1.000.000 of trees in 10 seconds. Link to comment Share on other sites More sharing options...
Nic H Posted June 30, 2008 Share Posted June 30, 2008 looking foward to trying out vray scatter^ Link to comment Share on other sites More sharing options...
RyanSpaulding Posted June 30, 2008 Share Posted June 30, 2008 It absolutely boggles my mind that no one has tried to replicate Vue's ecosystem feature. It's like a scatter, proxy, and place-objects-on-surface script all in one. Genius feature...yet it seems all scripts do either the scatter, or dropping objects onto a surface...never both. Link to comment Share on other sites More sharing options...
Trick Posted June 30, 2008 Share Posted June 30, 2008 memory management and rendertime geometry generation (on demand) is the main difference between this products. VRayScatter can generate 100k objects in near realtime. It can generate 1.000.000 of trees in 10 seconds. Well that sounds really great because this is what Groundwiz can NOT. Since you work with iCube I hope you can answer these questions. I have seen the demo video and some things are unclear. - Since the proxy is loaded from disk in the plugin how do you assign materials ? - Does the procedural material only randomly assign the 6 colors ? - Will you be able to assign random materials in the future ? - Will you be able to pick multiple proxies to scatter around on the same surface without loading the plugin each time for each proxy ? If not, how will the next instance of the plugin distribute the next proxy ? In other words will they get new coordinates so they don't overlap with the previous instance of VRayScatter ? - Will there be a package price if you are a single user with a renderfarm ? - Are the instances subobjects in the plugin so you can accurately place some of them if needed ? Link to comment Share on other sites More sharing options...
fobus Posted July 1, 2008 Share Posted July 1, 2008 Q. Since the proxy is loaded from disk in the plugin how do you assign materials ? A. Materials asssined to VRayProxies as usual. Q. Does the procedural material only randomly assign the 6 colors ? A. For now You can use 6 colors to produce infinite count of random color between them. Q. Will you be able to assign random materials in the future ? A. You can assign random materials by mixing random materials by VRayScatterTexture. Q. Will you be able to pick multiple proxies to scatter around on the same surface without loading the plugin each time for each proxy ? If not, how will the next instance of the plugin distribute the next proxy ? In other words will they get new coordinates so they don't overlap with the previous instance of VRayScatter ? A. For now the one VRayScatter object can use only one VRayProxy. There is a "seed" parameter to randomize different proxies. Q. Will there be a package price if you are a single user with a renderfarm ? A. We'll going to do discount system with multiply licenses. Q. Are the instances subobjects in the plugin so you can accurately place some of them if needed ? A. For now this feature is not implemented yet. Link to comment Share on other sites More sharing options...
fobus Posted July 2, 2008 Share Posted July 2, 2008 (edited) Some new videos with features of VRayScatter. temp.icube3d.ru/VRS-Create.wmv - 8,77 Mb temp.icube3d.ru/VRS-Masks.wmv - 20.1 Mb temp.icube3d.ru/VRS-Texture.wmv - 4.78 Mb rapidshare.com/files/126608489/VRS-Create.wmv.html rapidshare.com/files/126608490/VRS-Masks.wmv.html rapidshare.com/files/126608492/VRS-Texture.wmv.html Official feature list: icubeviz.com/services/VRayScatter Edited July 2, 2008 by fobus Link to comment Share on other sites More sharing options...
Trick Posted July 2, 2008 Share Posted July 2, 2008 When will it be released ? Will there be a demo ? Link to comment Share on other sites More sharing options...
fobus Posted July 3, 2008 Share Posted July 3, 2008 Q. When will it be released ? A. It's going to be released in August 2008. Q. Will there be a demo ? A. We'll try to produce demo version for al to taste it. Link to comment Share on other sites More sharing options...
fobus Posted August 25, 2008 Share Posted August 25, 2008 Demo version of VRayScatter plugin for 3ds max and VRay is available for download. http://icube.ru/index.php/news/vrayscatter_dostupa_demoversiya/ Link to comment Share on other sites More sharing options...
Eric Sosa Posted August 25, 2008 Share Posted August 25, 2008 humm, not quiet.....yet Pavel, links do not work looking forward as all the other guys Link to comment Share on other sites More sharing options...
Mike. Posted August 25, 2008 Share Posted August 25, 2008 download neil belvins scriptd. named Soulburn scripts. You can scatter vray proxies, drop them onto surface, randomize rotation scale translation. i use this for all big arrays (grass, forests...) I 'm quite happy whith results. Link to comment Share on other sites More sharing options...
Eric Sosa Posted August 26, 2008 Share Posted August 26, 2008 vray scater download links finally work Link to comment Share on other sites More sharing options...
fobus Posted September 3, 2008 Share Posted September 3, 2008 http://icube.ru/index.php/news/vrayscatter_uzhe_v_prodazhe/ Link to comment Share on other sites More sharing options...
Thablanch Posted September 4, 2008 Share Posted September 4, 2008 thanks, seems to do a nice job. Link to comment Share on other sites More sharing options...
Eric Sosa Posted September 5, 2008 Share Posted September 5, 2008 does it work only with SP2? got 1.5 RC3 but it has an error everytime max is launched ... Link to comment Share on other sites More sharing options...
