the white witch Posted May 26, 2003 Share Posted May 26, 2003 i finally got around the upload utility, here is an exterior i did... what do you think?... hope its not invisible.. haha Link to comment Share on other sites More sharing options...
sergio rocha Posted May 26, 2003 Share Posted May 26, 2003 yo witch thats cool. :ngelaugh: you just need to work those materials, expand your opacity maps and model the roof tops Link to comment Share on other sites More sharing options...
the white witch Posted May 27, 2003 Author Share Posted May 27, 2003 thanks for the compliment.. but what do you mean by expanding my opacity maps and building roof tops. could u explain further... Link to comment Share on other sites More sharing options...
STRAT Posted May 27, 2003 Share Posted May 27, 2003 Quote Originally posted by sergio rocha: need to work those materials, expand your opacity maps and model the roof tops he means there's a white edge round the people. make sure you adjust your opacity mapping to fit correctly. and the roofing is flat and mapped by a material. it looks unrealistic. he means model it up proper. give it some body. [ May 27, 2003, 02:18 AM: Message edited by: STRAT ] Link to comment Share on other sites More sharing options...
the white witch Posted May 27, 2003 Author Share Posted May 27, 2003 do you mean model the corrugatons of the roof... if thats what you mean strat, could you tell me any easy mtds of doing this....(e.g applying a displacement modifier in max?) Link to comment Share on other sites More sharing options...
STRAT Posted May 27, 2003 Share Posted May 27, 2003 there are hundreds of modelling methods, some even covered in the forums here (use the SEARCH option). You may also want to check this tut out - http://www.anteropedras.com/nrb/tut_rooftop.html Link to comment Share on other sites More sharing options...
the white witch Posted May 27, 2003 Author Share Posted May 27, 2003 thanks strat,i saw the tutorials, is that how u do your corrugations? that must take a lot of time especially for roofs with various pitch angles. would it be faster if done in cad. Link to comment Share on other sites More sharing options...
STRAT Posted May 27, 2003 Share Posted May 27, 2003 i dont actually do allot of residentials, and to be honest when i do i use clever mapping methods for the roof. Link to comment Share on other sites More sharing options...
the white witch Posted May 27, 2003 Author Share Posted May 27, 2003 clever mapping methods...hmm..hmm...share pls Link to comment Share on other sites More sharing options...
Jefferson Grigsby Posted May 27, 2003 Share Posted May 27, 2003 A darker, less saturated material would help tremendously. It also looks as though you are trying to simulate a standing seam, or metal roof. You probably would not see that on a residential, or maybe I am reading it wrong. Pay more attention to how the actual roof is built. Does it have a gutter, or some trim around the outside? DOes it have a flashing piece along the ridgeline, assuming it is a metal roof? These little details will help make it more believable. The only thing a map will not give you is the corregated profile against the sky background. You can overcome this by adding some trim piece to the ridge, which would be there anyway. I would also like to see more variation in the grass material, with a darker green. Link to comment Share on other sites More sharing options...
the white witch Posted May 30, 2003 Author Share Posted May 30, 2003 thanks guys, i will try it out over the weekend... maybe i should even move the work over to the wip section so i could put some more juice into it. Link to comment Share on other sites More sharing options...
