marchitecture Posted October 24, 2006 Share Posted October 24, 2006 I am a beginner with max and I am trying to give a realistic look to wooden planks. Should i use the materials that came with the program and how should the material be adjusted. thanks a zillion. Link to comment Share on other sites More sharing options...
IceAged Posted October 24, 2006 Share Posted October 24, 2006 My advice would be to take yourself down to the nearest woodyard, with a good digital camera, preferably on a dry overcast day, and grab some high resolution images there of some long wooden planks. If you find you need to take more than one photo to get the full length of the plank, (which need to be perpendicular to the camera), you can simply stitch them together later in Photoshop. Unless you really need a specific wood type, you can usually get away with adding filters in photoshop to your images, (eg, to turn pine into red cedar). As far as wood is concerned in 3D Max, you can either create each plank individually and apply a unique texture to each one, or use the material editor and UVW modifier to apply your materials to the surface - of course it depends on how much time you have, how much detail you need, etc. Just remember to use slightly different textures for large areas of wood, as each plank will always be unique. Link to comment Share on other sites More sharing options...
