Tommy L Posted October 24, 2006 Share Posted October 24, 2006 Apologies if this is answered already, i searched but couldnt find it: I am xreff-ing alot of rpc trees into a scene (max8) but there is a problem. When i change camera, the trees all look billboarded and are seen from the wrong view. I have attached an image of the problem. The two illustrations are region renders from different cameras. I tried changing all the settings in the 'mass edit' panel of the rpc modify panel, but nothing seems to help. Answers very much appreciated. Tom. EDIT: forgot to mention, when i reload the x-ref then the trees align themselves to the current view. But i need to animate this file. Link to comment Share on other sites More sharing options...
Matt McDonald Posted October 24, 2006 Share Posted October 24, 2006 If I remember correctly RPC don't like to be xref'd. I know that they have caused problems for us in the past when we have tried to. I hope that helps. Matt Link to comment Share on other sites More sharing options...
gfa2 Posted October 25, 2006 Share Posted October 25, 2006 And they don't like to be instanced either...best bet is just to copy them. Link to comment Share on other sites More sharing options...
Tommy L Posted October 25, 2006 Author Share Posted October 25, 2006 Yes they are copied, rather than instanced. However, i have opened an old file where we xreffed the rpcs. There was no problem in that job, i wonder if i have a preference/setting different in max? I really do need to get this fixed and dont know how. So any other ideas would be great. Otherwise i may just set up a matte file for the rpcs and comp them afterwards.... Link to comment Share on other sites More sharing options...
JamesTaylor Posted October 26, 2006 Share Posted October 26, 2006 Tom, if your rendering an animation using backburner, won't the xrefed file be reloaded for each scene / frame during the setup process etc. as such won't the RPCs then align themselves correctly.....??????? As you say, when you change camera views and have the problem with billboarding its always in the same file - the xref is only loaded upon opening the file and then by manually telling it to reload etc. may be worth sending a short sequence thro backburner to see what happens. James Link to comment Share on other sites More sharing options...
Tommy L Posted October 26, 2006 Author Share Posted October 26, 2006 Hell james, good to hear youre still alive mate, I dont think that will work. The file geometry is loaded into backburner as a comlete mesh(i think) at the beginning of the run. I dont think the xrefs are re-loaded. I may be wrong tho, ill give it a bash. Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 7, 2006 Share Posted November 7, 2006 did you get chance to try out anything on this?? did it work?? Link to comment Share on other sites More sharing options...
Tommy L Posted November 7, 2006 Author Share Posted November 7, 2006 Turns out im going a bit more conceptual on that file (the latest post in the 'chicago animation' thread in WIP section) so ive eilminated the RPCS for the time-being, but the problem was never solved. I compared it to another file where there was no problem and could find no difference. Just a weird one i guess. Link to comment Share on other sites More sharing options...
