Vray materials
flooatz
hello guyz. im a new bie in Vray rendering. my problem is this..
i imported an autocad file to 3dsmax for rendering aplication,
i put an ID for every layer for material aplication.
in material editor i use Multi/Sub layer, aplying vraymaterial and bitmap texture( i use jpeg format) with every ID in ON mode.
problem goes with i aply render nothing change in the material.
i still use the deafult setting in Vray render. does i have to change in render setting?
waiting for answer... thanks guys in advance..
You mean the rendered image gets only one material? Is that what's happening?
I'm not sure what you meant, but VRay doesn't really like Multi/sub-object materials (at least as I recall). I'd separate all objects by material you need to apply and use single materials for each one.
exactly Rick i use Multi/Sub in evry layer.. ( now i know) :)
if i use different material (VrayMtrl) in evry layer with separate material, do i need to assign ID for each of my layers? how to apply texture?
i dont use UVWMap... and my Vray render is default setting..
thanks guys.. and i realy want to learn more from u guyz..
