Frosty Posted October 30, 2006 Share Posted October 30, 2006 I'm currently working on an animation with a partner. I use C4D (obviously) and he uses Viz. We are planning to split the work so that I will handle all animation and he will handle textures/lights in VRay. Has anyone had luck transfering animated camera information between C4D and Max/Viz? I use a lot of tags such as target and align to spline while animating. I also plan to animate various objects in the scene. Link to comment Share on other sites More sharing options...
AJLynn Posted October 30, 2006 Share Posted October 30, 2006 Have you tried FBX files? If you can't get that to work right you may have to transfer the spline paths of the camera an target then redo the animation in Viz using those. Good luck. Link to comment Share on other sites More sharing options...
Frosty Posted October 30, 2006 Author Share Posted October 30, 2006 FBX does translate the animation.... if i only use keyframes. Anything animated with expressions is lost. My next step is to attempt to turn expresion driven animation into simple keyframes. Then I should be good to go. Link to comment Share on other sites More sharing options...
AJLynn Posted October 30, 2006 Share Posted October 30, 2006 Ooh, yeah, I haven't found any way to get expressions to translate to other programs. I tried on one school project, and gave up and kept everything in Cinema. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted October 30, 2006 Share Posted October 30, 2006 FBX does translate the animation.... if i only use keyframes. Anything animated with expressions is lost. My next step is to attempt to turn expresion driven animation into simple keyframes. There's probably a technique, possibly by plug-in, to create a set of keyframes, one at EACH frame, within C4D. Its brute-force, but maybe is your best bet. If you ask about that at CGtalk you will probably find an answer. I don't know myself, but I think I've read about doing that somewhere, sometime. Link to comment Share on other sites More sharing options...
AJLynn Posted October 30, 2006 Share Posted October 30, 2006 "Current State To Object" on the camera and target at each frame and batch the render in Viz Link to comment Share on other sites More sharing options...
Frosty Posted October 31, 2006 Author Share Posted October 31, 2006 to create a set of keyframes, one at EACH frame, within C4D. Its brute-force, but maybe is your best bet. Yes, that is exactly the approach I'm thinking. I cant seem to get AJ's method to work tho. Link to comment Share on other sites More sharing options...
Frosty Posted October 31, 2006 Author Share Posted October 31, 2006 Well, the "spline to position track" command gets me most of the way there. This approach loses the easing however. Link to comment Share on other sites More sharing options...
