spanish pants Posted October 31, 2006 Share Posted October 31, 2006 hi all, i recently made the swtich to max from xsi and while it´s going well, today i tried to do something in max that i can´t figure out. is it possible to skin shapes/splines together? this was so easy in xsi but this is driving me nuts!!!! Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted October 31, 2006 Share Posted October 31, 2006 Skin? Not sure I get you.... Link to comment Share on other sites More sharing options...
monkeysee Posted October 31, 2006 Share Posted October 31, 2006 Do you mean lofting? If XSI does it, it'll be similar to Maya's 'birail' tool... Link to comment Share on other sites More sharing options...
spanish pants Posted October 31, 2006 Author Share Posted October 31, 2006 i guess you could call it a "loft' but with out the need for a path, just the shapes. it involves selecting, in order, several shapes with the end result being the mesh. rats! i don't know if i'm explaining myself correctly. Link to comment Share on other sites More sharing options...
lambros Posted October 31, 2006 Share Posted October 31, 2006 ok, select splines and add the surface modifier (play a bit with threshold value to get results on screen). It would be better of course to draw NURBS and use the NURBS surface tool, since it gives you more options and control on the surface. Link to comment Share on other sites More sharing options...
