jtseaman Posted November 2, 2006 Share Posted November 2, 2006 This may be a really easy question...I'm extruding a closed spline to create a sofa and want to have a subtle radius on both ends. If I convert to an editable mesh or poly all I can do is extrude and chamfer the ends...Is there easy way to give the ends a slight radius? Link to comment Share on other sites More sharing options...
Tyorl Posted November 2, 2006 Share Posted November 2, 2006 I'm non VIZ user but MAX, as I know they are qiute the same so try this link, hope it'll help. http://www.neilblevins.com/cg_education/rounding_the_edges/rounding_the_edges.htm Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 2, 2006 Share Posted November 2, 2006 You can chamfer it like 3 or 4 times with decreasing values to get the radius you want. Link to comment Share on other sites More sharing options...
