RAYMOND Posted November 3, 2006 Share Posted November 3, 2006 keep getting this message no mater how i seem to set up advanced lighting "solution is invalid at current time frame" any ideas.... it worked yesterday Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 3, 2006 Share Posted November 3, 2006 This messages appears when something changed in the scene. A material, a light, an object (position, rotation, anything about it). Also, sometimes it happens if you have some object selected when you start the calculation. For some reason, Viz will think that object changed and display that message. If you are 100% nothing changed, simply ignore the message. Link to comment Share on other sites More sharing options...
RAYMOND Posted November 3, 2006 Author Share Posted November 3, 2006 well the geometry has changed but i am getting the invalid message after I run the solution and that takes almost a 1/2 hour.... got rad ckd in layer manager and it is active at all ck places...??? it created a much more better rendering when it worked yesterday... r Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 3, 2006 Share Posted November 3, 2006 got rad ckd in layer manager and it is active at all ck places...??? Didn't get it. Sorry. Link to comment Share on other sites More sharing options...
RAYMOND Posted November 3, 2006 Author Share Posted November 3, 2006 in the layer manager in viz you can ck what items you want radisosity also in the render form advanced lighting needs to be checked so basically i have set everything proper for it to do a solution however i did open up a previous version of the max file and it did work just can't see what the difference is.... problem with all the advanced lighting is of course getting the solution right. i should go with vray, maxwell, or something... Link to comment Share on other sites More sharing options...
