jucaro Posted July 3, 2002 Share Posted July 3, 2002 a lot is still needed to be done. as i am a first time user of lightscape, i need to better this immage. Your input, critiques, tips and suggestions are highly appreciated Link to comment Share on other sites More sharing options...
Jeff Mottle Posted July 3, 2002 Share Posted July 3, 2002 Hey jucaro, Look s liek you are off to a great start. Here are some things I'd look at modifying: 1. Try to desaturate your textures a bit so that they do not bleed so much into the environment and the ceiling. I sometimes find that processing to only 70-85 % is enought to get good radiosity without too much bleeding. Of course if you are doing lighting analysis this is not an option. 2. It looks like you have raised wall paneling represented by a bitmap. While it may work well for the back walls, it fall apart on the walls on each side. 3. If you can try to increase the segmentation on your tabletop and the sofa arms. 4. Are the lines on the top crown moulding supposed to be there? I ask because this is a possible Lightscape raytrace problem. Might be a tiling issue too. Keep posting your progress, we'd love to see it progress. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 26, 2002 Share Posted July 26, 2002 Can't see your image. All I get is a "remote linking forbidden" message in place of the picture... Link to comment Share on other sites More sharing options...
PI Posted July 26, 2002 Share Posted July 26, 2002 hi pare! aside from what jeff commented, i think the wall panelling should be properly aligned with the wall openings. the vertical lines should end properly or should be evenly spaced. Link to comment Share on other sites More sharing options...
