Groined arch
Sawyer
if you are worried about being exact.... you could make the vault in one elevation, copy it turn 90 degrees and boolean the two as an intersection.
if you're one of the booleans are evil supporters, just use it as a template to form your patch or poly models, then delete the guide.
Thats what I did originally. Worked fine but I could not reproduce it.
Eric how did you model that? Thats a bit more complicated than what I need.
Well... I cheated. I modelled it in Formz (mostly with extrude along a path). If you want to send me the specs of what you're trying to model I'd be more that happy to do it. This one only took me 20 minutes. Or I could send you this MAX file and you can take what you need from it.
