Tim Saunders Posted November 6, 2006 Share Posted November 6, 2006 I'm posting this at chaos as well. The thing is, I have never had this problem, not at this resolution. I have seen similar errors when rendering large resolution output, but this is different. And even a small 800px test render crashes. the attached image shows the 2 errors I have been getting. What the heck are filter tables? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 6, 2006 Share Posted November 6, 2006 Hum... have you tried turning that kallwall-opc.jpg map off and see what happens? I ain't no expert on this, but since the message says something about memory allocation, maybe there's something wrong with that map (resolution too high, maybe?). Just guessing. Link to comment Share on other sites More sharing options...
Tim Saunders Posted November 6, 2006 Author Share Posted November 6, 2006 Yeah, it just switches to a different bitmap. The first time I got the error it was for a bitmap on a lowpolygon car. I deleted the car then I got the error on a different bitmap, and so on. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 6, 2006 Share Posted November 6, 2006 Ok... these maps are on the intranet, right? Maybe that could be causing it (again, just guessing). I would copy them to a local folder and see what happens (again). Link to comment Share on other sites More sharing options...
lambros Posted November 6, 2006 Share Posted November 6, 2006 sometimes I have solved similar problems by switching to vray frame buffer. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 7, 2006 Share Posted November 7, 2006 That solves this problem sometimes because VRay's VFB requires less memory. But this is not the case, since Tim is using it already. Link to comment Share on other sites More sharing options...
thatch Posted November 7, 2006 Share Posted November 7, 2006 Try turning off 'filter maps' in your vray global switches. Link to comment Share on other sites More sharing options...
williamreyes292 Posted September 18, 2007 Share Posted September 18, 2007 does anybody solve this problem already? thanks! Link to comment Share on other sites More sharing options...
NADOUMAX Posted September 18, 2007 Share Posted September 18, 2007 can you help me to model this bench Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted September 18, 2007 Share Posted September 18, 2007 Wrong place, dude. Link to comment Share on other sites More sharing options...
