print job
blade911
hey everone
i have to get a flex billboard done for a scene done in vray
since its my first large size print job cud neone tell me wat resolution n settings i should use to achieve a good result? i did one around 3000 x 2500. will this be enough? the print guys jus mentioned they wanted somethin more than half the size of the board. dono wat they meant by this..
the size of the board will be newhere between 8x4ft to 8x8ft.
thanks
Most of the time 50 DPI is the highest rez I'd use for a billboard image, it would be even lower if the sign was extremely large. The thing about large signs is people won't be viewing them up close so you can get away with a lower resolution.
Agreed.
IMHO there is never a reason to render something larger than 5000 pixels wide. Even if that means the printed image would only be 30 dpi or so. Here's a case in point. An IMAX screen is larger than any bilboard would be and the resolution on that is only 4000 wide. I doubt anyone would ever say the image on the IMAX screen is to pixely.
pixels are dpi. you only need worry about dpi and pixel size when you have a specific size to print/render to.
ie, a 2000 pixel image is exactly the same size in pixels whether it be at 100, 200 or 300 dpi.
but a 20 inch picture will vary in pixel size at different dpi's, even though it's physical dimensions stay the same.
Where did you get that? For the most part, IMAX is a film projector, not digital (though I'm sure that's coming). A piece of 35mm film has an effective resolution of about 5000 to 6500 pixels depending on grain. IMAX uses 70mm film, which would be 4x as resolute as 35mm, but it runs through the projector sideways, thus delivering many times more surface area. So work shot directly on IMAX film would have an effective pixel size WAY beyond 4000.
Perhaps our good friend Chris Nichols would verify or adjust my figures, he works with this stuff daily. If I'm off I would like to know it.
