Jefferson Grigsby Posted November 8, 2006 Share Posted November 8, 2006 I am trying to use the hair and fur modifier in a scene I am rendering with mental ray. If I uses the default settings and "buffer" in the effect dialogue, the hair just renders black in mental ray. If I set it to a MR primitive, and use a mental ray material to shade the hair, the hair always renders white, regardless of what material I apply to it. The geometry emitter itself will show the color if the material, but the hair and fur itself just renders as white. Any help would be appreciated. thanks Link to comment Share on other sites More sharing options...
pixelperfectg Posted November 8, 2006 Share Posted November 8, 2006 I've attached two files for you to explore, one using the mr_prim, the other using geometry. Both have assigned materials. More info here that might be useful: http://forums.cgsociety.org/showthread.php?t=425634 Jeff Link to comment Share on other sites More sharing options...
Jefferson Grigsby Posted November 9, 2006 Author Share Posted November 9, 2006 thanks, was not linking the shader into the interface, yet assigining through the material editor. Link to comment Share on other sites More sharing options...
nisus Posted February 19, 2007 Share Posted February 19, 2007 Quote thanks, was not linking the shader into the interface, yet assigining through the material editor. What does this mean? What do you mean? nisus Link to comment Share on other sites More sharing options...
pixelperfectg Posted February 19, 2007 Share Posted February 19, 2007 It means he wasn't using the built in material map slot on the hair, but trying to apply a material from the MEDIT directly to the hair instead. Link to comment Share on other sites More sharing options...
