superdave Posted January 20, 2003 Share Posted January 20, 2003 http://dwarts.3dup.net/images/both-buildings.jpg Link to comment Share on other sites More sharing options...
nisus Posted February 28, 2003 Share Posted February 28, 2003 pls post a correct link Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted February 28, 2003 Share Posted February 28, 2003 Dude! Lose the flare! It's too damn strong, taking over the whole image! Also try creating dif. lights, with dif angles and all. The overall look is really flat. [] Rick Link to comment Share on other sites More sharing options...
STRAT Posted February 28, 2003 Share Posted February 28, 2003 teehee, lense flairs. they went out with tank tops and flairs Link to comment Share on other sites More sharing options...
Sawyer Posted February 28, 2003 Share Posted February 28, 2003 Real quick note to keep in mind for lens flares. not only are the passe and overused but they are a photgraphic mistake. Professional photographers really get paid to avoid that kind of stuff. So they might look real but only on CG work will they be seen. Link to comment Share on other sites More sharing options...
Christian Miranda Posted February 28, 2003 Share Posted February 28, 2003 Hi superdave, Your images lack a more detailed shading. I would use some sort of fakeosity, it produces the softer shadows which are more natural and a can be produced by skylight and/or diffuse reflections. Regarding your materials I would use a little bit of noise mixed with the textures and produce more detailed maps on your image editting software of choice. I can see some repetitive textures on them as well. Bigger and tileable maps would help as well. Overall your modeling seems to be ok. Just pay attention to the shading part. Keep us posted! Link to comment Share on other sites More sharing options...
John Dollus Posted February 28, 2003 Share Posted February 28, 2003 On the top image: 1. darken the building elements as they recede from the camera to add a bit of depth to the facade. 2. If you are going to add cars, you need to go all the way. The place looks deserted with only a couple and a huge parking lot. 3. Tiling on the parking lot repeats too much. Try using a mix map with a noise mixer to quickly breakup the pattern. Ideally, find another texture. 4. Add some banners from the lightpoles or flags around the entrance to draw attention to the front and add some color. The others: 1. Much too saturated. Especially on the greens. 2. The brick posts are using a stacked bond instead of a running bond. With posts that small, a running bond would probably look better. Also increase the number of bricks in the material while increasing the mapping size to eliminate the tiling. 3. Like everyone else said, lose the flare. Link to comment Share on other sites More sharing options...
nisus Posted March 1, 2003 Share Posted March 1, 2003 Hey guys, thanks! This thread was posted more than a month ago and no one has replied at that time So tnx again! rgds nisus Link to comment Share on other sites More sharing options...
