jtroupe Posted November 8, 2006 Share Posted November 8, 2006 I am trying ot avoid the tiling that you get with grass on a big area by making a composite material of 2 different grass materials. So far I haven't had any success. Either one or the other shows up, not both. I also wanted to include a third image to get the look like the grass had just been mowed and you get the lines back and forth. (See attached image). [ATTACH]17192[/ATTACH] I am using scanline render to do my images. Any suggestions would be helpful. Thanks. Link to comment Share on other sites More sharing options...
Arnold Gallardo Posted November 8, 2006 Share Posted November 8, 2006 Looks fine to me it looks like it was 'mowed' Link to comment Share on other sites More sharing options...
jtroupe Posted November 8, 2006 Author Share Posted November 8, 2006 That image is not mine, I was just showing it to illustrate what look I am going for. Link to comment Share on other sites More sharing options...
The_architect06 Posted November 8, 2006 Share Posted November 8, 2006 you have to use a Mask (black & white) map, put your first material on white areas & the 2nd on black areas & they will both show up Link to comment Share on other sites More sharing options...
dinhtuan Posted November 9, 2006 Share Posted November 9, 2006 You can use Mix material with grass maps at color slots and a mask (noise map) at Mix amount slot to mix. Link to comment Share on other sites More sharing options...
