LukeC Posted November 9, 2006 Share Posted November 9, 2006 Hi guys, sorry if this topic has been covered, but I was just wondering what files were required for a machine to render mental ray via backburner and if there was a compact install that can be made or exists just for this purpose. The reason I ask is, it would be easy to deploy a small package of the essentials to each machine rather then go through the max install process every single time on every single machine (30+) as i just did that for max 8 a few months ago and were now on max 9. Any help would be greatly appreciated! cheers Luke Link to comment Share on other sites More sharing options...
Verma Posted November 9, 2006 Share Posted November 9, 2006 I don't think there's any compact version option available anymore. It used to be in the old releases but I haven't seen it for a long time. You can create a network deployment image of Max 9 and deploy that image on multiple computers at the same time. No need to install the product separately on each renderfarm machine. Check the documents section on Max 9 disc, there's network administrator's guide which explains this in details. Link to comment Share on other sites More sharing options...
LukeC Posted November 9, 2006 Author Share Posted November 9, 2006 Thanks for the reply. I came across the network deployment on the disk not long after I posted, so I did that and it worked, however I had a few issues including a custom 3dsmax.ini but resorted to manually replacing it after the machine was setup Link to comment Share on other sites More sharing options...
