need help...missing environment dialog
the white witch
don't know anyway around this....i downloaded the trial version of max9, installed it...it has been working fine till yesterday..when the environment/effects dialog went awol...i have tried restarting max over n over...but it just doesn't appear....even tried using the keyboard shortcut...n io need to control my exposure contols/environment... any tips...my trial days are running out...[in tears]...was beginning to enjoy mr3.5
Go to 'Customize' - 'Load Custom UI Scheme', and then load 'DefaultUI', and then restart Max.
If that doesn't work you might want to check the '3dsmax.ini' file in the installation folder, (in the case of version 8, usually 'C:\Program Files\Autodesk\3dsMax8\3dsmax.ini').
Search for [EnvironmentDialogPosition] and confirm that the dimensions given below correspond to your screen area.
I had a problem with missing dialogue boxes when my spare monitor died, and the boxes were set to display on the second monitor - this sorted it.
Sending my '3dsmax' file will not help you, because i am running version 8. I have not used 9 yet, so i am assuming that the file has the same name - it might be possible that the location has changed, so try running a search for it in windows. (By the way the '.ini' is the file extention, not part of the actual name).
You could always try reinstalling Max but i can't guarantee that the trial will still work afterwards.
When you go to 'rendering>environment' does the top bar of the max window turn gray? if so, the window is open but hidden (this happens to me with adobe apps all the time) press alt+spacebar, press the down arrow once, then press enter, then without moving the mouse, click and hold the left mouse button and move your mouse around until you see the window.
did you work on two screens and now only one?
i found that all menus that are moved onto a second screen when working on two screens stays on the second screen if you unplug the second one. Then, the only way to get it back is to plug in the second one again and move the menus back!
good luck
ok, before un-installing, lets try something, you say you don't get the
3dsmax.ini file, but max needs an ini file to tell it how to load, maybe they changed it?
which ini file are there in the root folder? if you re-create the correct ini file into an empty one max should re-load to the default start setup.
If you go into widows display properties - identify, find out what number your screen/s is. Its probably 1 or 2. Then, select the required menu in max. Then hit (i think) ctl+alt+1, or ctl+alt+2 (depending what your screen number is. The selected floater will centre to the screen number. I havnt done this for a long time, but i lost a bunch of menus when i was on-site with my laptop (multiple monitors unplugged) and i started up max when not re-configured to one screen. It worked then (max8 win xp) but i forget what the controls were. If you figure it out, post the answer!
just completely delete 3dsmax.ini out of your program directly. I work on two screens as work and when i log in from home sometimes I can't see a dialog. So I just cut the .ini out and drop it on my desktop. When max loads and can't find the .ini it just loads it's default values and recreates the file for you. (basically the same as reinstalling) You'll get everything back in the initial locations on screen.
nice thing is you can use that .ini to store and take your prefs with. Such that when I get back in the office after removing it from the directory. I just take it off my desktop and put it back, and all is back to normal.
(if you haven't found the .ini just run a search on your local harddrives for 3dsmax.ini)
