Need some help for interior test
sedus69
I just try to do in interior Scene, very Simple model, except for celling.
I use basic map, and very simple illumination Ambient light 1.0 light blue + 1 Sun 1.0 light yellow
First Bounce IRR MAp High 10/35
Secondary Bounce LC 1000
After many tries I stil don't get good shadows, and don't really succed to have a better contrast Except using Photoshop.
And don't know what parameter to tweak to get clean "checkers" (sorry for my english)
I post 3dsmax File (8.0 Vray 1.5rc2)
original image from VFB
and Post processed image VFB + AO.
Please Help me learning those parameters.
Link to 3dsmax file
i think i forgot some attachment....
I can't download your file right now (I'm not home), but... You IrrMap settings seem to be the problem. When you say "high 10/35" you mean Hemispheric Subdivs = 10? If so, try increasing that back to 50 and see what you get. It'll take a tad longer to render, but might be the cause of your not-so-fine shadows.
id stick with GI and loose the ambient..i think those openings will work perfectly with this lighting setup..maybe a couple of vray light planes on the windows openings, if you really wanna add in shadows, id suggest a single direct target light with vray shadows enabled..
IRR = high
LC = 1000
hope this helps, cheers
I know Hemispheric Subdivs is quite low, but I tried to follow the "Valdo FlipSide Tutorial" so I modify the rQMC multiplier from 1 to 16, so I reduce the HsPh Subdiviser.
Rendering time is "fast" les then 10 Min on my C2D6600@3.3 Ghz 1024*650px.
I'll test with more HSubs.
