CookiE Posted November 10, 2006 Share Posted November 10, 2006 How do other ppl make there renders with real grass look? Do you use Displacement or modeled grass? I am trying to get a nice scene with grass climbing up the edges of my pathments etc and the only way i know how to do this is scatter huge amounts of grass blades with a rotation transform. But this puts 1000's apon 1000's of polygons in the scene and massivly kills rendering time let alone if i was to vray it... Link to comment Share on other sites More sharing options...
Arnold Sher Posted November 10, 2006 Share Posted November 10, 2006 vray displacement... If you search this forum i am sure you can find a tutorial on it... I remember seeing one... Link to comment Share on other sites More sharing options...
gfa2 Posted November 10, 2006 Share Posted November 10, 2006 Vray fur also. The Vray displacement will get you grass that is basically standing staight up, while the fur can do grass and weeds that curve and hang different directions. Link to comment Share on other sites More sharing options...
CookiE Posted November 10, 2006 Author Share Posted November 10, 2006 Vray fur also. The Vray displacement will get you grass that is basically standing staight up, while the fur can do grass and weeds that curve and hang different directions. Thanks for the info but im wanting something in normal scan line max can you use these options without using the vray renderer? Link to comment Share on other sites More sharing options...
gfa2 Posted November 10, 2006 Share Posted November 10, 2006 max has a hair and fur render effect built in, you could probably get that to do what you want. Link to comment Share on other sites More sharing options...
CookiE Posted November 12, 2006 Author Share Posted November 12, 2006 max has a hair and fur render effect built in, you could probably get that to do what you want. OK ill give that a go and see what i can do with that Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 12, 2006 Share Posted November 12, 2006 You can, indeed, use Max's inbuilt Hair&Fur. It's a bit tricky to get grass to look right, but it has been improved for Max 9, so it probably got easier. Link to comment Share on other sites More sharing options...
CookiE Posted November 12, 2006 Author Share Posted November 12, 2006 You can, indeed, use Max's inbuilt Hair&Fur. It's a bit tricky to get grass to look right, but it has been improved for Max 9, so it probably got easier. Im still on 7 lol so ill have to see what i can do Link to comment Share on other sites More sharing options...
Tyorl Posted November 13, 2006 Share Posted November 13, 2006 Im still on 7 lol so ill have to see what i can do Just update your max to 7.5 and u'll get the Hair&Fur Link to comment Share on other sites More sharing options...
kippu Posted November 13, 2006 Share Posted November 13, 2006 well try the scatter trick.... take a poly , make one grass stalk.... scatter it on the ground you want the grass... Link to comment Share on other sites More sharing options...
