Problems in AfterEffects
Mario Pende
Helo!
I rendered from Lightscape pgn. frames.
Now when I import pgn. as sequence and then drop them in composition I have option to render pgn. out to various video formats like avi., wich I want.
When I add job to renderQueue and then render out to avi. format I get file thats 1GB large with fps around 15 when I playback (you dont get smooth video)!
Help!
p.s.the farme rate in LS and AE are the same 30fps!
If you render to an uncomressed AVI then your system is likely not fast enough to play it back at the full frame rate, the bitrate just ends u being too high for reading from the harddrive in realtime.
You may still want to render to that uncomressed AVI to have as a full quality clip for editing, it depends on what workflow you are using and what your final output is to be.
To watch good quality video in realtime with no major compression issues you could try DV video compression, PAL or NTSC (NTSC if you are really working on a 30fps project)
Chances are that will be good enough for a fianl edit too, although it may not stand up to further post / compositing work as well as the uncompressed AVI would have.
compress to WMV (windows media video) and also to quicktime (MOV) use sorenson 3 for quicktime, burn both files to a DVD and let them choose which one they want to look at...
The H.264 codec for quicktime is probably better than the sorenson 3, but unless they have the newest quicktime player it won't play, where as the sorenson will play on any quicktime player...
I also heard abouth AdobePremiere.
Can it also import stills as sequence and work on them like in AE?
Yes it can its for video editing (piecing together lots of small clips into one large video)
If you already have after fx, it'll be perfectly capable for doing what you want...
