cjlopez4 Posted November 13, 2006 Share Posted November 13, 2006 Is anyone using RPC's with Vray1.5 and noticing major slow downs with renders? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 13, 2006 Share Posted November 13, 2006 Well, since RPCs are based on opacity maps, you probably should expect VRay the be slower with them. Link to comment Share on other sites More sharing options...
abl_langs Posted November 19, 2006 Share Posted November 19, 2006 i think u should uncheck the "billboard" option when using the rpc.. it works fine with me.. Link to comment Share on other sites More sharing options...
Brian Smith Posted November 19, 2006 Share Posted November 19, 2006 If you're using more than 100 RPCs, then you're probably doing yourself an injustice. That's my personal cutoff and I never go above it because the preparing RPCs time gets to be too much after that point. Chances are, if you're working on a scene where you can see more than 100 RPCs at once, you are far enough away from them to warrant using much more efficient content. Link to comment Share on other sites More sharing options...
