TheGrandmaster1 Posted November 13, 2006 Share Posted November 13, 2006 Sorry to bother you fine folks once again. I have run into a bit of a pickle. It seems simple, yet it is not. Does anyone know what this odd speckling is on my render here. I have my noise set down to 0.005. Adaptive QMC Image sampler, with Mitchelle-Netravelli Anti-Aliasing filter. I have a mixed HDR map in the lighting and reflection slots for the lighting. In fact, it's the same lighting system used for the Vray materials site's demo materials. I was practicing to see how my chip model would look with it. My material subdivs are between 16 and 20, so that shouldn't be it. Any ideas? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 13, 2006 Share Posted November 13, 2006 Do you have any lights in there? If so, increase your light's subdivs to 32 (8 is default). Link to comment Share on other sites More sharing options...
BrianKitts Posted November 13, 2006 Share Posted November 13, 2006 as silly as it sounds 0.005 can be noisey depending on the scene. take it to 0.001 or 0.002 and see if that fixes it. Link to comment Share on other sites More sharing options...
TheGrandmaster1 Posted November 13, 2006 Author Share Posted November 13, 2006 Rick Eloy said: Do you have any lights in there? If so, increase your light's subdivs to 32 (8 is default). Nope, it's HDR the whole way. BKittsARC said: as silly as it sounds 0.005 can be noisey depending on the scene. take it to 0.001 or 0.002 and see if that fixes it. I'll give that a shot then, and report back. Thanks for the advice. Link to comment Share on other sites More sharing options...
TheGrandmaster1 Posted November 13, 2006 Author Share Posted November 13, 2006 Alas. That did not help. What should the material Subdivs be? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted November 13, 2006 Share Posted November 13, 2006 Try setting the reflective subdivs to 32 for a start and, if that doesn't work, try a higher number. If none of these help, increase the subdivs multiplier under rQMC. Link to comment Share on other sites More sharing options...
JamesTaylor Posted November 14, 2006 Share Posted November 14, 2006 If its HDRI lighting, have you switched off your default max light that will be present? It can be done in the global switches section of the render dialog box. Link to comment Share on other sites More sharing options...
FlytE Posted November 14, 2006 Share Posted November 14, 2006 Set your qmc noise to 0.002 or 0.003 , set your materials reflective and refractive subdivisions to 50, set your light subdivisions to 10... try a test with those settings and see if its better. Link to comment Share on other sites More sharing options...
