Distributed rendering ( urgent )
darkblue_wire
Hi all
i have 3 pcs 3.2 ,1gb ram for each
i have to render a large project using v-ray at this coming few days
so that i did some test to render an old small project on 2 pcs
i have archived the file then open it on the other pc & add the ip address to the server distribute in v-ray system
while rendering network conection mark show that data sent & recieved between pcs
but the result as attatched............:confused:
please help me or guid me to a direct link where i could read about rendering distribution on v-ray (urgent please )
thanks
u see the other computers should find the textures as exactly as the same paths as the original computer.... so if some texture is in c drive then the slave computer should also find the texture on c drive... easiest way is to map your folders on the slaves with the same letter....
hi
thanks maria
is n`t it really confue ?
ok u r right i have to do this i will try tomorrow moorning to set pathes for maps files
much thanks for help
& i will report the result & i will care about having all maps at the same folder while mapping the large project ( by the way it will be a factory & adminstration area ...)
thanks again
