chow choppe Posted November 18, 2006 Share Posted November 18, 2006 Please see the attached image for my problem Link to comment Share on other sites More sharing options...
Brian Smith Posted November 18, 2006 Share Posted November 18, 2006 It's coming out that way because you arent using interpolation. When you create a simple circle, there are only 4 vertices, though it looks smooth because it's interpolating. With terrain, interpolation is not automatic, you have to specify it in the Simplification rollout. A better way to get it right though is to, before do the terrain command, attach the lines together using the edit spline modifier, and then go to Segment subobject mode and divide the segments. This adds the number of vertices you want and the result when you use terrain next time will be smooth curves. Link to comment Share on other sites More sharing options...
chow choppe Posted November 19, 2006 Author Share Posted November 19, 2006 so basically its divide command i have used it to smooth the lofts along curves didn't knmow that it will work for terrain also Thanks i will try that Link to comment Share on other sites More sharing options...
mskin Posted November 20, 2006 Share Posted November 20, 2006 try using the normalizespl modifier too. It will place vertexes at determined distances along the spline.... i think. helped me out with a terrain model. Link to comment Share on other sites More sharing options...
