hrvojezg00 Posted November 18, 2006 Share Posted November 18, 2006 I`m doing some vray 1.5 shots and I wonder one thing.Is there a way to put a background image with vray sun/sky setup cause seems I need to have vraysky background in the enviroment background? http://img452.imageshack.us/my.php?image=petr2vf3.jpg http://img523.imageshack.us/my.php?image=petr9qy6.jpg Link to comment Share on other sites More sharing options...
ShaunDon Posted November 18, 2006 Share Posted November 18, 2006 Nice renders, buddy. I like the second angle a lot. As far as a background image, as long as you put the VRaySky in the override map slot under the VRay Environment settings, you can use whatever image you want in the Max environment. As far as VRay is concerned it will only see the VRaySky when it's calculating the lighting. Shaun Link to comment Share on other sites More sharing options...
kippu Posted November 18, 2006 Share Posted November 18, 2006 maybe its just me ... but i find the blue in the vray sky too dark for my taste .. maybe if you follow lwf ...it comes out right Link to comment Share on other sites More sharing options...
hrvojezg00 Posted November 19, 2006 Author Share Posted November 19, 2006 thnx for your answers, so how do you put background image for compositing?photoshop or 3dmax? Link to comment Share on other sites More sharing options...
kippu Posted November 19, 2006 Share Posted November 19, 2006 i personally use photoshop.... save it as a tga and put the background in its layer... easier for me to adjust the levels Link to comment Share on other sites More sharing options...
hrvojezg00 Posted November 19, 2006 Author Share Posted November 19, 2006 since I`m a total noob at photoshop would you care to explain how to do that, or where can I find some tutorials about it? Link to comment Share on other sites More sharing options...
manta Posted November 19, 2006 Share Posted November 19, 2006 I've always had a problem with TIFF's and photoshop, one would expect that when you open it up in photoshop, it would come in with a transparent background, but they don't, so I use PNG's 24bit with alpha channel checked, when you open them up, they have a transparent background, so you just put your sky or whatever behind it... Link to comment Share on other sites More sharing options...
hrvojezg00 Posted November 20, 2006 Author Share Posted November 20, 2006 thnx for the tip! I have vray sky in vray enviroment slot and whatever pic I put in 3dmax env. slot I get black background.Is there a way to put a pic in background slot?I need it cause of the angle of camera? Link to comment Share on other sites More sharing options...
martin walker Posted November 20, 2006 Share Posted November 20, 2006 I render my stills (and anims) out in PNG format with an Alpha channel...then I can drop anything behind it in post editting software....works a treat for me Link to comment Share on other sites More sharing options...
BrianKitts Posted November 20, 2006 Share Posted November 20, 2006 maybe its just me ... but i find the blue in the vray sky too dark for my taste .. maybe if you follow lwf ...it comes out right yes LWF is a must with the vraysky Link to comment Share on other sites More sharing options...
hrvojezg00 Posted November 20, 2006 Author Share Posted November 20, 2006 what exactly is lwf?how do I use it? Link to comment Share on other sites More sharing options...
