Darkpaul Posted November 19, 2006 Share Posted November 19, 2006 Hi guys, I need your help to do something particular.. I'm in lighting design and I've been workin for years with the legendary lightscape... now, 'cause I need also videos with dynamic and changing colours lights, the only solution seems to be to pass to 3ds max... I have a question.. if you can look at these pictures you will see geometrical elements attached to the ceiling (Barrisol false lighting ceilings). I need them to seem turned on... for example with some halo effect (as for example the one used for the tubes...but it seems not working with large surfaces...) do you have some suggestion please??? thanx a lot. Paolo Link to comment Share on other sites More sharing options...
Tyorl Posted November 20, 2006 Share Posted November 20, 2006 How about postproccessing? Just save it to file and in Photoshop use DiffuseGlow filter. U may also try to use LensEffect Glow. Link to comment Share on other sites More sharing options...
birbidouille Posted November 20, 2006 Share Posted November 20, 2006 open your image in photoshop, duplicate the background layer. In the duplicated layer, delete everything except your ceiling lights and apply a gaussian blur (5~10). this will do the trick. Here is the result: Link to comment Share on other sites More sharing options...
Wayn Posted November 21, 2006 Share Posted November 21, 2006 Hi there, If you have vray can try vray light materials.... http://www.joepizzini.com/VRAY/Tutorial.htm Link to comment Share on other sites More sharing options...
Darkpaul Posted November 22, 2006 Author Share Posted November 22, 2006 thanx guys, I was tryng with the advanced lighting ovveride with radiosity but seems it doesn't work... thanx a lot Link to comment Share on other sites More sharing options...
Hazdaz Posted November 24, 2006 Share Posted November 24, 2006 Just apply a Glow Effect in MAX. Renderings out fairly quick (yet unfortunately you won't be able to see it in the viewport) and even reflects. Link to comment Share on other sites More sharing options...
