The_architect06 Posted November 20, 2006 Share Posted November 20, 2006 hi everyone... just wondering if anyone knows the shortcut key for " repeat last" button in the edit geometry as am welding thousands of vertex & its taking ages doing it by click. Link to comment Share on other sites More sharing options...
BrianKitts Posted November 20, 2006 Share Posted November 20, 2006 I can't answer your question you posed, but I can suggest why don't you just select all of the vertecies you want to weld at one time and then hit the weld button once (make sure you're distance is set just larger than your two closest points) Link to comment Share on other sites More sharing options...
The_architect06 Posted November 20, 2006 Author Share Posted November 20, 2006 I can't answer your question you posed, but I can suggest why don't you just select all of the vertecies you want to weld at one time and then hit the weld button once (make sure you're distance is set just larger than your two closest points) this way they will all get welded in one point , i need to weld each two vertics in one point...anyway thanks for answering..i figured it out it's the " ; " key..it really saves a lot of time Link to comment Share on other sites More sharing options...
