david.jones Posted November 24, 2006 Share Posted November 24, 2006 Hi, i have only really been using vray recently. Previously, when i've created windows etc, i have always usually created the entire window, including glass, as a single object, and used multi mat's for glass frame etc. But doing this with vray i get a problem, glass loses its ability to affect the opacity of the shadows, once it is in a multi material. I've tried loads of ways to get round this, but i am stumped, anyone else found this to be a problem? I guess it now just means a different way of working in future, but it's going to be a big pain in the arse to open all my previous models and detach all glass to a seperate object, when anything from my library is used. Link to comment Share on other sites More sharing options...
martin walker Posted November 24, 2006 Share Posted November 24, 2006 David dont know whats happening there, I use Multi Sub Materials 100% of the time, and never had this problem. Link to comment Share on other sites More sharing options...
david.jones Posted November 24, 2006 Author Share Posted November 24, 2006 Really?? Thanks for the quick reply martin. Ok, incase this was due to a corrupt file or material, i created a new scene, new materials, one 100% opaque, one 50% and one 0%. Created two boxes, one has those mats as a multisub, and the other has been detached to 3 seperate objects, with the same mats as individual, not multisub. And, there we go, the multi sub versions dont cast shadows properly. I really cant think what i'm doing wrong. Link to comment Share on other sites More sharing options...
martin walker Posted November 24, 2006 Share Posted November 24, 2006 strange, ive attached a recent image ive done with the multi sub material assigned, as u can see its OK do you want to send your test scene to me and I'll try on my PC ? pixel_ninja@hotmail.com Im using Max8 and V-Ray 1.5 Link to comment Share on other sites More sharing options...
pg1 Posted November 24, 2006 Share Posted November 24, 2006 I read something about this on chaosgroup there is a known bug with vray RC 3 This solution was posted by lukx My fix for "Known issues: (*) "Affect shadows" and "Affect alpha" options do not work for VRayMtl's inside a Multi/subobject material. This will be fixed as soon as possible" Lukx is coming with help If you still need to use for example glass in mulisub material first create vray blend material and as base material put this your material in which you need to use affect shadows. That's it Affect shadows will work. I didn't check affect alpha cause I never use it. Here is the link to the post on chaosgroup http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17187 I haven't tried it but Vlado gave it the thumbs up so it should work Hope it helps pg1 Link to comment Share on other sites More sharing options...
david.jones Posted November 25, 2006 Author Share Posted November 25, 2006 Thanks alot pg1. Yep, that works a treat. Weird though, because martin redered my test scene fine without changing anything, must be i'm missing a patch or something. Link to comment Share on other sites More sharing options...
